What to replace while motors apart and getting built (ie bolts, gaskets, water pump)
Old Feb 6, 2008 | 05:47 AM
totsie7944's Avatar
Default What to replace while motors apart and getting built (ie bolts, gaskets, water pump)
Hey guys,
I tried to keep a list last night while I was taking the block and head apart, but oilly hands and paper don't mix well. Please help me continue my list (think through whats in the block and head) to make sure I re-assemble it all properly. So far I have:
-Big bolt missing from tranny support (bottom of motor)
-2 10mm bolts for that wireharness around oil pump (pulley)
-timing belt lower pulley (cracked teeth taking it off....oops!)
-crank bolt
-2 keyways (T-belt pulley and balancer)
-water pump & o-rings
-thermostat
-oil pickup tube gasket
-oil pan gasket
-valve cover gasket
-clutch bolts (What part # for ARP?)
-flywheel bolts (Part # for ARP?)
-assembly lube
-honda bond
-knock sensor (broke that getting **** off motor....oops!)
Old Feb 6, 2008 | 06:46 AM
Bbasso's Avatar
Default Re: What to replace while motors apart and getting built (totsie7944)
Ya gotta stop all these threads!!!
You're driving me nuts
Seems like this project is too big for you and maybe you should have it finished by someone who knows. Just saying...
Old Feb 6, 2008 | 07:54 AM
totsie7944's Avatar
Default Re: What to replace while motors apart and getting built (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Ya gotta stop all these threads!!!
Seems like this project is too big for you and maybe you should have it finished by someone who knows. Just saying... </TD></TR></TABLE>
haha well there isn't much tech stuff going on in HT or the ITR forum for that matter anymore, personally I enjoy them more than the typical picture, 'check this out' threads we always have....
I took the block and head apart...wasn't much to it, everyones gotta first time for everything. I mean after I get the motor back and re-assemble it, I'll have it back in and finished in one night.
I have help from a friend whos done this many times before...I just wanted other 'builders' thoughts if there were any other parts that we mighta just forgot when making a list since we couldn't update as we went.
Old Feb 6, 2008 | 08:03 AM
The Dude's Avatar
Banned
Rebuilt distributor
new or rebuilt oil pump
new timing belt and tensioner
ARP head and main studs
complete bottom end and top end gasket kit
TB gasket
VTEC gasket
acessory belts
Modified by The Dude at 11:37 AM 2/6/2008
Old Feb 6, 2008 | 08:39 AM
totsie7944's Avatar
Default Re: What to replace while motors apart and getting built (The Dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Dude &raquo;</TD></TR><TR><TD CLASS="quote">Rebuilt distributor
TB gasket
VTEC gasket
acessory belts
Modified by The Dude at 11:37 AM 2/6/2008</TD></TR></TABLE>
distributor is new
timing belt is new
have arp head studs
where can I get these gasket kits?
Old Feb 6, 2008 | 09:00 AM
RTW DC2R's Avatar
t00ts, you know there are some outstanding build threads scattered around HT that are very useful.
Old Feb 6, 2008 | 09:08 AM
totsie7944's Avatar
Default Re: (RTW DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">t00ts, you know there are some outstanding build threads scattered around HT that are very useful. </TD></TR></TABLE>
Yea I figured, I just didn't have time at work today to be searching and reading up....I'll look into some tonight. Just figured I'd start a thread during the day to see
Old Feb 6, 2008 | 09:12 AM
The Dude's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">
distributor is new
timing belt is new
have arp head studs
where can I get these gasket kits?</TD></TR></TABLE>
Get a new timing belt tensioner too.
IL4, Password JDM, King motorsports, Search Button when it doesn't p0wn yur ***...
but PM len on H.T. for discount pricing or I'll have to smack you with a blunt object.
Old Feb 6, 2008 | 09:19 AM
totsie7944's Avatar
haha thanks. I always order from Len or Sonsacura. Great prices haha.
Old Feb 6, 2008 | 09:27 AM
The Dude's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">haha thanks. I always order from Len or Sonsacura. Great prices haha. </TD></TR></TABLE>
ARP bottom end studs/bolts will run you @ $150, cheap insurance.
Sometimes you can get packages cheaper, like this...
http://www.inlinefour.com/timingbeltkits.html
Old Feb 6, 2008 | 09:30 AM
totsie7944's Avatar
http://www.inlinefour.com/timingbeltkits.html </TD></TR></TABLE>
well I already have head studs...Just need to get main studs. Ill probably buy all my ARP stuff from Summit
Old Feb 6, 2008 | 01:10 PM
Kavehman's Avatar
Well can you take some pics as your going along with it, on how your doing all of this. It would make the threads a lot more interesting,,,, and we need eye candy.
Old Feb 6, 2008 | 01:24 PM
totsie7944's Avatar
Default Re: (Kavehman)
I plan on taking pics for the rebuild...people can look at that and do it in reverse if they ever need to pull a motor and take it apart...I figured using clean parts would make it easier to document...
Old Feb 6, 2008 | 01:29 PM
BlueR's Avatar
Ill probably buy all my ARP stuff from Summit</TD></TR></TABLE>
AHEM!
Old Feb 6, 2008 | 01:32 PM
totsie7944's Avatar
Default Re: What to replace while motors apart and getting built (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">
AHEM! </TD></TR></TABLE>
All my ARP bolts and studs have now been bought from Tran haha
Old Feb 6, 2008 | 01:36 PM
BlueR's Avatar
much better
Old Feb 6, 2008 | 02:09 PM
The Dude's Avatar
Banned
All my ARP bolts and studs have now been bought from Tran haha</TD></TR></TABLE>
In for rebuild pics.
Check out Dave_B s rebuild thread, pics and good tips there.
Tips from me;
Don't reuse any gaskets.
Replace all oil seals.
Study a Helms and replace all "one-use" self locking fasteners, (ex. the spring bolt nuts at the cat. inlet.) Also any fasteners that are corroded or damaged.
Before assembly, chase threads in tapped holes and clean out dirt and shavings with compressed air.
Old Feb 6, 2008 | 02:16 PM
totsie7944's Avatar
haha sounds good man. I planned on cleaning everything up before re-installing anyway because I want a bling engine bay lol
Old Feb 6, 2008 | 02:28 PM
The Dude's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">haha sounds good man. I planned on cleaning everything up before re-installing anyway because I want a bling engine bay lol</TD></TR></TABLE>
Two problems I've seen on rebuilds, not replacing timing belt tensioner and reusing VTec gasket.
Oh yeah, NAPA for break in oil. Thet sell it labeled as such. When new, my B18 was slow to break in and I pro'lly coulda' run another change of breakin oil thru it.
Old Feb 6, 2008 | 02:53 PM
totsie7944's Avatar
Oh yeah, NAPA for break in oil. Thet sell it labeled as such. When new, my B18 was slow to break in and I pro'lly coulda' run another change of breakin oil thru it. </TD></TR></TABLE>
well Im going to replace the tensioner....but I don't use the spring. I rip that little bastard out of there and then get a coat hanger and pull up pretty hard. Gets it a lot tighter, but not toooo tight haha
Old Feb 6, 2008 | 04:47 PM
IntegraTionR's Avatar
oil pan baffles or Mugen oil pan!!!
Mishako129
Aug 17, 2012 10:03 AM
RacerX3888
Feb 20, 2010 11:46 AM
DJaeMac
Honda Civic (2001 - 2005)
Mar 22, 2007 08:03 AM
ranta18
Mar 9, 2004 06:16 PM
Del Sol Man
Oct 11, 2003 01:52 PM
