To boost or not to boost?
Ok, just wanna know what you guys think about a set up I am pursuing.
Car is a '91 Acura Integra four door DB1. Doing an LS-Vtec with the following:
-'91 B18A block (fresh), PLANNING ON: shot peened rods, balanced rotating assembly.
-CTR STD Pistons from YCP (Wrist pins, rings, etc., all included and brand new)
-'95 GSR Head, new valve seats, as well as internal parts, all stock
-ARP head studs, arp wave-lock rod bolts
-GSR Oil Pump
-GSR water pump
-GSR timing belt
Now here's the boost part...I have a turbo kit made for my car (b-series), direct bolt on, but was wondering with all the mentioned above, do you think I should boost it? Here's my turbo set up:
-Eclipse GSX turbine, internal wastegate (7000 miles on it since rebuild)
-Custom log manifold
-Custom 2 1/2" down pipe
-450CC DSM Injectors
-255lph Bosch fuel pump
-Missing link (for 90-93 integras)
-Manual boost controller (going electronic when I find a good deal)
-Greddy Type R BOV (Overkill, I know, but I got it with my set up)
-Also not made yet, but getting 2 1/2" intercooler piping into a side mount for now, and then upgrading to a front mount
Also thinking about doing a full silicone intercooler piping. But that's another thread...
Anyways, let me know what you guys think. Thanks
Modified by denraweb at 1:23 PM 2/6/2008
-GSR Oil Pump
-GSR water pump
-GSR timing belt
Lol...I doubt I will sell it. It's hard for me to sell cars that I put alot of work into. With the exception of the pistons, I have installed everything myself. With a good tune, I think I will be happy for awhile before I decide to do another swap!
I guess I'll boost it...I mean I have almost everything right now besides the piping. Boost it is!
I would turbo it if i were you...i love my boosted GSR. The only hesitation i have is that the 14b is a tiny little turbo for a high revving Honda engine. You're going to have boost quickly, but it will fall off in the top end. As long as you're ok with that, i say go for it. If you have any further questions, check out the Forced Induction Forums.
collinsvc15
May 28, 2011 08:27 AM
jEE
Jul 18, 2004 06:56 AM
