what is idle (noob at manual)
Old Feb 5, 2008 | 08:31 PM
jr408's Avatar
Default what is idle (noob at manual)
what exactly is IDLE. im new and got a 98 integra ls
Old Feb 5, 2008 | 08:56 PM
superchi's Avatar
Default Re: what is idle (jr408)
This is a joke right?
ZE12O's Avatar
dude, you have hella questions, how about making one post with general questions or do a more broader search of the components of an engine, and how they work.
howthingswork.com has great stuff on engines and DOHC VTEC.
the idle function has to do with where the rpm gauge needle sits when the engine is on, the gas pedal is not pushed or you are in neutral. (assuming your tachometer works correctly)
idling, your integra should be around 800rpm. to warm up your car it may be higher than for a brief period of time if you are starting in cold weather.
:edited:
Modified by ZE12O at 10:23 PM 2/5/2008
DA_9's Avatar
the rpm at any give time during the operation. When in neutral your idle drops to like near 1000 rpm.
Old Feb 5, 2008 | 09:00 PM
St Jimmy's Avatar
* B A N N E D *
HIGH Welcome to Wiki!!!!! http://en.wikipedia.org/wiki/Idle_speed
Old Feb 5, 2008 | 09:20 PM
superchi's Avatar
Default Re: what is idle (ZE12O)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZE12O &raquo;</TD></TR><TR><TD CLASS="quote">idling, your integra should be 1k+rpm, no more than 2k rpm. to warm up your car it may be higher than 2k for a brief period of time if you are starting in cold weather.</TD></TR></TABLE>
Under no load conditions your idle speed should NOT be at 1,000 RPM or more unless you are in the warm up period or something is wrong with your car. Here's a clip from the Acura Service Manual
Under conditions when your heater fan is on HI and the air conditioner on, your idle should float within the 800-900 RPM range.
Old Feb 6, 2008 | 03:42 AM
Dogginator's Avatar
Daisy... Daisy...
The idle should be 750+-50 RPM with a warm engine and no load (all lights, radio, heater, etc. turned off).
lrhtech
24
Mar 8, 2016 04:00 PM
Tom_Chooch
Apr 9, 2015 10:29 AM
kitt
Apr 29, 2010 11:57 AM
Blue teg
Nov 27, 2001 01:12 AM
