Idle Issues with my 98 gsr
Old Feb 5, 2008 | 07:23 PM
JDMDC2-209's Avatar
Default Idle Issues with my 98 gsr
I bought this car in november not expecting anything to be wrong with it because I don't want to spend more money to fix it. When the engine is warm, every once in a while the temp idles up and down between 0800-1000 only for a few second. Today I was going to work and the idle would stay between 1000 to 1500 only for few seconds. Then the BAD CHECK ENGINE LIGHT CAME ON, i learned that it is the thing behind and on top of the intake manifold. Do I have to buy a new one or should i check other things prior. I just want my engine to stay at 0800 rpm and be normal... What precautions can iI do to insure this wil happen. Any reply will help thanks James......dotastars209@yahoo.com or PM me...THANKS FOR READING
Old Feb 5, 2008 | 07:24 PM
JDMDC2-209's Avatar
Default Re: Idle Issues with my 98 gsr (JDMDC2-209)
Now the check engine light is off but it still idles funny, any remarks or advice
Old Feb 5, 2008 | 07:42 PM
PrinceAli132's Avatar
*** How-To*** Clean Your FITV aka Fast Idle Thermo Valve
***How-To Clean*** Your IACV a.k.a. Idle Air Control Valve
Ali
Old Feb 5, 2008 | 07:52 PM
63HMOOB's Avatar
check to make sure you got coolant in it. it could be you idle air control. might need to replace it or you might have a vacuum leak. check out to see wat the check engine light code was. that should help a little.
noxon511
Jul 13, 2014 11:51 PM
frostykue
Mar 28, 2013 08:29 PM
babohyungjin
Mar 25, 2010 01:38 PM
dystro
Jan 30, 2006 11:22 AM
cchev
Jan 23, 2004 04:00 PM
