LEAKING OIL! HELPPPP
Old Feb 5, 2008 | 07:14 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default LEAKING OIL! HELPPPP
on the back of my head/block i'm leaking tons of oil through the headgasket
I re-torqued the head by loosening one nut at a time and re-tightning it..
i'm using ARP's and I torqued it down to 65 ft/lbs with the arp moly lube and it's squirting out horribly as I start and idle the motor..
the motor has never been started for more then 5 seconds.. everything is brand new...
any suggestions guys?
Modified by ohsnapzafingcu at 10:50 PM 3/9/2008
Old Feb 6, 2008 | 06:25 AM
Honda Bull's Avatar
Default Re: LEAKING OIL! HELPPPP (ohsnapzafingcu)
Is the O-ring on the PCV can good? Is it the right size PCV can?
Regardless, a freeze plug will plug the hole up.
Good luck!
Old Feb 6, 2008 | 11:02 PM
slowcivic2k's Avatar
Plugging the PCV can and will inevitably blow out your rear main, oil pan gasket, and possibly the oil pump seal.
There is no way 4 quarts of oil is coming out of that hole. Even if it did, to get that kinda flow just from cranking it would have to come from the pump, which in itself is also hard to believe. The pics certainly don't show 4 quarts of oil.
Check to see if you double gasketed the oil filter. Check the oil pressure switch as well.
You'll need to have two people, one to crank it over, and the other to flashlight the leak. A can of brake cleaner should be used to wash any excess off the block to spot the leak more easily.
Old Feb 7, 2008 | 05:42 AM
Honda Bull's Avatar
Default Re: LEAKING OIL! HELPPPP (slowcivic2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k &raquo;</TD></TR><TR><TD CLASS="quote">Plugging the PCV can and will inevitably blow out your rear main, oil pan gasket, and possibly the oil pump seal.</TD></TR></TABLE>
More than likely. ohsnapzafingcu, I'd definitely try to get that canister sorted out before you go plugging the hole. Normally freeze plugs are used to plug that in order to run another external catchcan. Not to just retire the PCV system from action. The PCV is a pressure release from the block. Engines need to have some form of it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k &raquo;</TD></TR><TR><TD CLASS="quote">There is no way 4 quarts of oil is coming out of that hole. Even if it did, to get that kinda flow just from cranking it would have to come from the pump, which in itself is also hard to believe. The pics certainly don't show 4 quarts of oil.</TD></TR></TABLE>
That's not the pics of his actual motor that is leaking.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k &raquo;</TD></TR><TR><TD CLASS="quote">Check to see if you double gasketed the oil filter. Check the oil pressure switch as well.</TD></TR></TABLE>
He brings up a good point. Make sure it is from that exact spot as you say. I doubt it'll be the oil pressure, but it could be the oil filter. That's about the only other thing immediately there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ohsnapzafingcu &raquo;</TD></TR><TR><TD CLASS="quote">how would u recommend me stopping the leak? new o-ring and hondabond?</TD></TR></TABLE>
You won't need Hondabond at all. Just get another O-ring, either from Honda or just hit up an Advanced Auto/Autozone/Pepboys and get distributor O-rings. One of the assortment boxes should have one that fits fine. That's all I did. Just put a small bead of oil around the O-ring so it doesn't tear going in.
You're O-ring probably isn't bad though is it?
Old Feb 8, 2008 | 08:02 AM
Default Re: LEAKING OIL! HELPPPP (Honda Bull)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Bull &raquo;</TD></TR><TR><TD CLASS="quote">
You're O-ring probably isn't bad though is it?</TD></TR></TABLE>
it looked better then the one i pulled from my friend's block.. and without the bolt in the bracket it was really loose too, i'm fixing to go pick up an o-ring from honda and see if this fixes it..
if it doesn't i'm gonna try and weld some bungs on my valvecover and do an external breathing system..
i don't see where else the oil could be coming from. this sucks
Old Feb 8, 2008 | 10:14 PM
i just put the new O-ring on, it feels like it sits a little bit tighter.. we'll see what happens tomorrow morning when i get some jumper cables!
Old Feb 8, 2008 | 11:57 PM
Garage 808 Hatch's Avatar
if it really lost that much oil, its probably from the oil filter, probably have it double o-ringed, as in when the old filter was removed the seal stayed, then a new one was installed over it, and they will pour oil out like you describe because they are pressurized. pull the filter off and see if there are 2 seals on it
Old Feb 9, 2008 | 08:09 AM
Default Re: (Garage 808 Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch &raquo;</TD></TR><TR><TD CLASS="quote">if it really lost that much oil, its probably from the oil filter, probably have it double o-ringed, as in when the old filter was removed the seal stayed, then a new one was installed over it, and they will pour oil out like you describe because they are pressurized. pull the filter off and see if there are 2 seals on it</TD></TR></TABLE>
i really doubt it, this is the first oil filter on there since it's been taken apart and hot tankd.. i'll check it out though.
Old Feb 12, 2008 | 06:33 PM
question..
if i re-torque the head down should i loosen everything up and re-do it? or just make sure all the nuts are to specs?
Old Feb 12, 2008 | 06:45 PM
DOHCter's Avatar
Oil will not come pouring out of the vent catch can like that. You can leave the can off and should only get a light amount of oil spatter out along with excess pressure inside the block escaping, since thats what that can is for anywayz. If you have oil just pouring out when its started within a few seconds, its definately the filter or pressure sending unit somewhere. The oil passage for pressure doesn't go there inside the block unless its cracked inside somewhere, in which case you are totally f%#@*d.
Old Feb 13, 2008 | 07:58 PM
Default Re: LEAKING OIL! HELPPPP (DOHCter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCter &raquo;</TD></TR><TR><TD CLASS="quote">Oil will not come pouring out of the vent catch can like that. You can leave the can off and should only get a light amount of oil spatter out along with excess pressure inside the block escaping, since thats what that can is for anywayz. If you have oil just pouring out when its started within a few seconds, its definately the filter or pressure sending unit somewhere. The oil passage for pressure doesn't go there inside the block unless its cracked inside somewhere, in which case you are totally f%#@*d.</TD></TR></TABLE>
well i found a few more bolts taht were loose.. tightend them up.. and figured out my headgasket is leaking
Old Mar 11, 2008 | 12:47 PM
ttt
Old Mar 13, 2008 | 12:17 PM
bump
Old Mar 15, 2008 | 10:53 PM
anything i should look for if i pull my head off tomorrow?
Old Apr 14, 2009 | 02:55 PM
scspeed's Avatar
This thread is prolly pretty old but im curious...what did you find out?? Im having a similar problem..it seems to be coming out of the head as well...
Mentat Ghola
May 13, 2010 10:02 PM
EGgoJDM
Dec 1, 2009 12:05 PM
noodlez1390
Jan 5, 2009 04:29 PM
DO_ITR_YoungD_19
Honda S2000
11
Nov 24, 2008 08:38 PM
92redhatch
Aug 27, 2006 09:52 AM
