How do I fix this? eg civic.
Old Feb 5, 2008 | 03:28 PM
ejoner's Avatar
Default How do I fix this? eg civic.
I recently got into a little accident. Frames fine only sheet metal got damaged (fender,hood). This part on my car also got a wrinkle in it I'm going to try my best at fixing it but if I can't get it perfect is there a way I can order a new piece and just weld it in? Were can I get a new piece? junkyard? or is there a website I can order it from. Note: this is not my car but damages are outlined in pic damage does not go past seam sealer or frame rail. Weak!EG I can take these pics down upon request.
Old Feb 5, 2008 | 04:11 PM
civic4lif's Avatar
Default Re: How do I fix this? eg civic. (ejoner)
I dont think that part is replaceable. Your going to hafta have a shop pull it on a frame rack and then body it.
Old Feb 5, 2008 | 04:17 PM
ejoner's Avatar
Default Re: How do I fix this? eg civic. (civic4lif)
No I'm for sure that it can be removed and replaced, theres seam sealer on both of its edges and its just spot welded in. Its just sheet metal and doesn't affect the body's geometry. I just need to know were to find one before I go junkyard hopping to find a civic. I can just slap my fender on but I don't want it to look half *** either.
Old Feb 5, 2008 | 05:17 PM
Disease's Avatar
It's called a left fender apron cause it is on the left side of the car. I do not believe they make aftermarket apron's. You can try but I would get it through HONDA. Might cost a bit though. You can try one from a junk yard. They would just cut that whole area out and you would have to cut it off the donor.
Old Feb 5, 2008 | 05:46 PM
CE-CE's Avatar
i know in canada you can get the apron and it in not too expensive. it is very easy to change, just remove the seam sealer and drill the spot welds out
Old Feb 5, 2008 | 06:01 PM
msinsky14's Avatar
Default Re: (CE-CE)
that part from honda is only 80 bucks online. i get my parts through college hills honda
Old Feb 5, 2008 | 06:21 PM
powerflow's Avatar
Default Re: (msinsky14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Disease &raquo;</TD></TR><TR><TD CLASS="quote">It's called a left fender apron cause it is on the left side of the car. I do not believe they make aftermarket apron's. You can try but I would get it through HONDA. Might cost a bit though. You can try one from a junk yard. They would just cut that whole area out and you would have to cut it off the donor.</TD></TR></TABLE>
You must be tired.
Old Feb 5, 2008 | 06:48 PM
ejoner's Avatar
Default Re: (powerflow)
Oh cool thanks, 80$ is a bit steep I think I'm just going to go to a junkyard with a saws all and cut one off a bit further then the spot welds and do all the drilling at home. Might be a little too much to ask but do you guys know if its the same on a sedan and a coupe? One more question is it possible to re-weld it on with a mig? welder (type of welder that wire is automatically fed threw the tip of the gun)? Thanks for all the help guys.
Old Feb 5, 2008 | 08:53 PM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
If your going to use "Flux core" make sure you set the amp on really low. Or else your just going to make a hole right through the thing.
Old Feb 6, 2008 | 02:39 AM
Disease's Avatar
Your right I was tired lol that is the right side. Yes you can weld it with a mig welder. That is how most people put it in.
Old Feb 6, 2008 | 02:52 PM
ejoner's Avatar
Default Re: (Disease)
Great, thanks guys now all I need to do is find a civic at a junk yard.
Old Feb 8, 2008 | 10:24 AM
jdm24seven's Avatar
Default Re: (ejoner)
just cut it and go Right hand Sides Drive
Old Feb 8, 2008 | 04:03 PM
ejoner's Avatar
Default Re: (jdm24seven)
L<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm24seven &raquo;</TD></TR><TR><TD CLASS="quote">just cut it and go Right hand Sides Drive </TD></TR></TABLE> Lol I just want my car to be drivable again.
Old Apr 29, 2009 | 09:58 PM
Heatherly's Avatar
I have that kind of damage in my hatch, but it goes all the way down into the frame rail... could you just cut it from the top all the way to the bottom of the frame rail and put a new chunk in??
Old Apr 30, 2009 | 04:50 AM
Disease's Avatar
You would have to post up some pics. Most of the time if you are going to have to cut a rail out of a car and weld a new one in, it is not even worth it.
You would need to pull the car on a frame machine to get it to were it needs to be first. Then you would section the rail according to manufacturers sectioning procedures for your specific car. You also have to account for the fact that you need to remove the motor to do this. Makes life much easier.
I suggest you get a new car if it is really bad.
Old Apr 30, 2009 | 09:25 PM
gorillafart's Avatar
yeah for sure its replaceable... i'd get professional help be4 i replace anything cuz you needa make sure the rest of the enginebay is in alignment... i cant tell too surely by the pictures... but it looks like a pull would do the job. baby not a replacement... and just to let you know its "geometry" does affect the car... its not just there for kicks n giggles lol
Old May 3, 2009 | 05:44 AM
19civic93's Avatar
This is your lucky day. I have both sides cut from the shock towers. I still have them after removing the core support on a front end repair I did a while back on a coupe. Here they are. Also if anyone needs prelude one's I have that too for a 97-01.
gorillaglue#4
Welding / Fabrication
Jul 28, 2017 09:54 AM
VeryUnoriginal
Apr 7, 2014 10:19 AM
checko
Jan 31, 2011 04:53 PM
93bubble87
Paint and Body
May 17, 2010 10:48 PM
Reego.
28
Jan 21, 2005 11:22 AM
