ls vtec problem! 95 gsr
Old Feb 5, 2008 | 03:13 PM
skUnK2jdm's Avatar
Default ls vtec problem! 95 gsr
hey whats up guys i have a problem with my lsvtec! it wont past 3200 rpm i do have cels but i cant check them! I had rhd conversion done but for some reason it wont let me check the cels.
so is there any thing i can check so i can fix this? iam getting fuel and spark, but for some reason it wont let me pass 3200 rpm
and it also idles at 2k
any suggestions will help! thanks
iam thinking it might be the computer (p72)
Old Feb 5, 2008 | 03:16 PM
skUnK2jdm's Avatar
Default Re: ls vtec problem! 95 gsr (skUnK2jdm)
Old Feb 5, 2008 | 04:30 PM
ls19integra95's Avatar
you found the little green rubber piece that holds the service connecter and bent a paper clip into a U and put it into each side the connector, then turned car to the on position without starting it and then checked to see if the cel started blinking? there shouldnt be any problem with being able to read the codes unless you didnt have a good connection in the terminal (paper clip not in well enough) and if the cel just stays solid then that means your ecu no good...
i say try checking your ecu again to try to read the codes and then also check make sure all your grounds are tight, (valve cover to rad support, trans to frame, battery to frame, AND the one that goes to top of thermostat housing), i had that one one the thermo housing come loose and mine did the same things as yours...
Old Feb 5, 2008 | 06:50 PM
skUnK2jdm's Avatar
Default Re: ls vtec problem! 95 gsr (ls19integra95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls19integra95 &raquo;</TD></TR><TR><TD CLASS="quote">make sure all your grounds are tight, (valve cover to rad support, trans to frame, battery to frame, AND the one that goes to top of thermostat housing), i had that one one the thermo housing come loose and mine did the same things as yours...</TD></TR></TABLE>
oh **** i forgot about that!!
Old Feb 5, 2008 | 09:19 PM
jdm tommy's Avatar
when i had my tps and map sensors mixed up it woudlnt let me rev you should check those
Old Feb 5, 2008 | 09:21 PM
skUnK2jdm's Avatar
Default Re: ls vtec problem! 95 gsr (jdm tommy)
will do thanks!!
Old Feb 5, 2008 | 09:50 PM
skUnK2jdm's Avatar
Old Feb 5, 2008 | 10:08 PM
did you figure it out? if so what was it?
Old Feb 6, 2008 | 04:56 AM
skUnK2jdm's Avatar
not yet but deff will be trying when i get home from work
HONDRETTI
May 8, 2008 12:52 PM
skUnK2jdm
30
Feb 7, 2008 04:50 AM
whitemike1644
Apr 3, 2005 05:00 PM
itr_dc2
Dec 5, 2004 03:50 PM
95GS-Racin
May 22, 2003 01:25 PM
