EF9 Front end
Hey Honda-tech need help mounting my ef9 front end and side skirts i have searchet but can't find what im looking for any info wood be great...........thanks
yea thats one of my problems the T-bar does not line up with the hood so it does not latch and the mounts on the bumper support are not the same as the usdm one
I just installed my side skirts all you need is some double sided tape,self taping screws and washers depending on the screw you may not want the washer,but it helps support it better. All this can be found at your local homedepot.
if its the complete front end,take off your front bumper and the bumper filler,then your headlights (jdm head lights dont use the brackets usdm ones have they bolt right on),you could use your stock fenders, they are the same as jdm minus the side markers.take off the T-bar and put the jdm one,at this point you could put the new old sir hood,and start trying to get it to close right.I did a combination of moving the latch on the t-bar more forward and same to the hood latch.You have to use a grinder.You also need patience because there is a lot of test fitting and grinding.In the end i had to use washers on my hood latch to get it to raise up a bit and align with my fenders.Now you can put on your jdm headlights and corner lights. After that you can put on your new old jdm bumper filler straight forward.Then then you can put on your jdm bumper,you will also need longer boltsand washers between your cars cross member and the bumper to get the ends of your bumper to line up with your fenders.Most of this is just my own experience it was the first time i installed my front end.Other people may have a different way but it worked for me.gl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miguelp22 »</TD></TR><TR><TD CLASS="quote">Do you have only the jdm bumper and the rest is usdm stock.</TD></TR></TABLE>I have the hole front end it's just the the bumper and T-bar /hood to line up with the latch isn't it a bolt up a fair.......................
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by socalrex88 »</TD></TR><TR><TD CLASS="quote">i have pics of how to mount the ef8 one if you want?
</TD></TR></TABLE> Thats cool it might help..............
So youve had this for at least 5 days now and you still dont have it on ?!
Wow
takes me about to take on and off an ef front in an hour or so
and thats even long
but 5 daysssssss
have you even tried ??
Wow
and thats even long
but 5 daysssssss
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NATEDEEZY »</TD></TR><TR><TD CLASS="quote">do you have the jdm radiator support too</TD></TR></TABLE> Yea i do have it......!!!!!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ~sp33~ »</TD></TR><TR><TD CLASS="quote">What about the correct bumper support?</TD></TR></TABLE> I have the one that came with the front end...........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x4thGenCafe »</TD></TR><TR><TD CLASS="quote">So youve had this for at least 5 days now and you still dont have it on ?!
Wow
and thats even long
but 5 daysssssss
</TD></TR></TABLE> THE FRONTS ON IT'S JUST THE T-BAR AND BUMPER THAT ARE NOT LINEING/BOLTING UP RIGHT.......
Wow
and thats even long
but 5 daysssssss
From: Where the wild things are in, NY, United States of America
MAYBE YOU SHOULD TAKE YOUR CAR TO A BODY SHOP. It sounds like your stabbing in the dark. so instead of fawkin it up, take it to a place that does that kinda ****.
crx_si-r
Jun 13, 2009 03:32 PM
B16Anees
Aug 21, 2003 02:01 PM
