have problems with my hatch
Old Feb 5, 2008 | 08:21 AM
wuchang's Avatar
Default honda civic hatch problems..help??
hi...i gotta 92 hatch...that gotta d16z6 motor
for some reason my car idles between 1500-2000rpm...when cold when hot it idles at 1200-1300rpms. ...plus the car is always running rich....i cant seem to find the problem wrong with it can anyone help me out....i turned the thing by the throttle body or whatever all the down to and it stills idles high...
i thought it would be my ecu becauuse it was chipped but i swapped it with my brothers stock hatch ( but is not vtec) and it still idles high so i really dont know help me out!!
Modified by wuchang at 9:33 AM 2/5/2008
Old Feb 5, 2008 | 08:27 AM
B16B_coupe's Avatar
HRD PKR
Default Re: have problems with my hatch (wuchang)
Tried searching yet?? search "idle" in the top right side of your screen
possibly a iacv??
Old Feb 5, 2008 | 08:31 AM
wuchang's Avatar
Default Re: have problems with my hatch (B16B_coupe)
thats what i thoguht it was too but that part is 200 dollars..at autozone..
Old Feb 5, 2008 | 08:34 AM
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wuchang &raquo;</TD></TR><TR><TD CLASS="quote">thats what i thoguht it was too but that part is 200 dollars..at autozone..</TD></TR></TABLE>
u can try to clean it by using brake cleaner. check all the vacume leak. u are running p28 ecu ,right ? and any other mods on the engine ?
Old Feb 5, 2008 | 08:35 AM
B16B_coupe's Avatar
HRD PKR
There is a way you can clean it, like i said searching is your friend. Took 2 sec on google http://www.superhonda.com/foru...44463
Probot's Avatar
so clean your existing IACV
Old Feb 5, 2008 | 11:04 AM
wuchang's Avatar
yes p28 chipped ecu, phantom grip lsd, msd..
also my dizzy was advanced i retard it back to the middle but the idle is still high
Old Feb 5, 2008 | 11:06 AM
wuchang's Avatar
Default Re: have problems with my hatch (Probot)
clean with brake cleaner...so do i just spray all over it
Old Feb 5, 2008 | 11:09 AM
B16B_coupe's Avatar
HRD PKR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wuchang &raquo;</TD></TR><TR><TD CLASS="quote">clean with brake cleaner...so do i just spray all over it</TD></TR></TABLE>
Did you read the link i sent you?
Also might want to think of getting it tuned if its running rich.
Old Feb 5, 2008 | 11:26 AM
forcefedferio's Avatar
A vacuum leak would cause a lean condition, not a rich condition, so deffinetely try cleaning the IACV out real good.
Old Feb 11, 2008 | 09:26 PM
wuchang's Avatar
cleaned it still doing the same thing
Old Feb 11, 2008 | 09:28 PM
wuchang's Avatar
i cleaned it and it still does it...
Old Feb 11, 2008 | 11:35 PM
sevindust2404's Avatar
* slaps head *
you can allways lower your idle with your throttle cable adjustment.. chances are if you bought the car that way its probly due too the last owner..
Old Feb 12, 2008 | 08:22 AM
wuchang's Avatar
u guys have anymore ideas
Old Feb 12, 2008 | 09:44 AM
blk92_d16's Avatar
I had the same issue with my Z6 swap in a VX hatch on a P06 chipped/slotted/converted ecu. Clean the hell out of the IACV and stuff, changed the TB & IM gasket too...but nothing. TB screw was at its lowest setting as well. I said screw it! and had lived with it for a year until I got a more reliable Civic for a DD.
Old Feb 12, 2008 | 09:47 AM
wuchang's Avatar
so what other problems do you guys think i have...this car is really pissing me off
sdr KEL
May 15, 2008 03:36 PM
blindsk8er1013
Sep 11, 2005 06:35 PM
vtecb20coupe
Jun 13, 2005 02:17 PM
nY's FiNeSt
19
Aug 20, 2003 09:23 AM
ciRcuitJerk
Jul 6, 2003 09:21 PM
