wtb obd2 b18, b16, or gsr motor also wtb ls tranny
hey i need a torque mount for an ek/b18, torque mounts are the mounts that bolt near the clutch slave cylinder not the top tranny mount thanks let me know
Modified by whatisJDM at 3:45 AM 2/6/2008
Modified by whatisJDM at 10:18 AM 2/7/2008
Modified by whatisJDM at 2:10 AM 2/9/2008
Modified by whatisJDM at 12:56 AM 2/17/2008
Would you be interested in an LS-VTEC with LS tranny? Can include an ITR p73 that runs the motor great. Approx 10k miles on the build.
Head:
B16A2 Cylinder Head
ITR dual valve spring set
ITR retainers
Jun Type 2 cams
Skunk 2 Pro series Cam Gears
Power Enterprise Timing Belt
Golden eagle Cam plug
Golden eagle Vtec dowels
Charcoal grey powder coated Valve Cover
AEM Cold Air Intake (Flat black)
Block:
B18A2 block.
Std bore PR3 pistons
Shot peened B18a rods with ARP rod bolt inserts
ITR water pump
ITR oil pump and pick up
Golden Eagle Oil Sandwich kit for LSVtec conversion
H22A breather nipples
New B16a2 Lower Timing cover
Transmission:
LS Transmission
All new OEM Honda bearings and seals in transmission
ACT Street lite flywheel
Head:
B16A2 Cylinder Head
ITR retainers
Jun Type 2 cams
Block:
B18A2 block.
ITR water pump
Transmission:
LS Transmission
I aint wasain!!! i was involved in a bleaching accident when i was little changed the skin and it got in my eyes and burnt off part of my eye lids, so now i unfortunatly appear to be white
bump still need a motor people ive found everything else, help me out looing for a good running obd1 ls longblock with or with out tranny
TTT
TTT
pmed
come on a site full of so called car guys and no one has long block? come on i wont bite you aint my gf
wm5holla
37
Mar 9, 2003 11:25 AM
