beginner with driving manual
when i drive my car 1998 integra ls (manual) and i go on 3rd gear and im on the 2 rpm and when i step on the gas all the way down i cant go any faster it just makes some wierd noise. why is it like that. Can i only step on the gas when im on like 4 or 5 rpm because when i do that it doesnt make any noise but when im on 2 rpm it does and i cant go any faster.whats the problem here?
I also just had a tune up
sounds like your motor needs a tune up. Check the cap and rotor of the dizzy, check your wires. if thoes are good move onto a fuel problem or timing. Assuming your driving right and not shift into a higher gear to soon, does this problem occur in all gears
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rikter »</TD></TR><TR><TD CLASS="quote">Good grief. How many clutch/tranny/help threads do you have to post all relating to the same thing? You've got 11 posts and you're already annoying.
Just make the one!
-Rik</TD></TR></TABLE>
owned
Just make the one!
owned
What kind of noise is the car making a 2K RPM?
You do realize that our cars are torueless. Our powerband is higher up in the RPM range therefore going full throttle in a honda at low RPM is not like a domestic.
Ali
Ali
Just make the one!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superdat1 »</TD></TR><TR><TD CLASS="quote">
owned </TD></TR></TABLE>
LMAO.....
Just down shift that sh*t.....
Just make the one!
LMAO.....
DrewBrews
Mar 6, 2011 02:16 AM
tallblondkid
14
Sep 16, 2004 03:10 AM
CTL
13
Mar 18, 2004 09:49 PM
