my idle is messing up
Old Feb 4, 2008 | 03:06 PM
GSTDA9's Avatar
Default my idle is messing up
when my car is cold its at 3k then when it warms up it goes down to 2k and once in a while it will go down to 1500
HELP ME HONDA PPL
Old Feb 4, 2008 | 06:13 PM
efyou's Avatar
Default Re: my idle is messing up (GSTDA9)
sounds like a vacuum leak, leaks cause idle to rise
Old Feb 4, 2008 | 06:19 PM
Tizight's Avatar
Mines been doing that since I've had it.
Like efyou said its probably a vacuum leak.
Check the iac or fitv?
Old Feb 4, 2008 | 07:33 PM
GSTDA9's Avatar
Default Re: my idle is messing up (efyou)
nope all my vacums are fine
wat r the other things
Old Feb 5, 2008 | 01:42 PM
efyou's Avatar
try your idle screw, look at your throttle body like your looking into it and look around the opening for a goldish flathead screw, keep your car running and either tighten or loosen the screw and listen if your idle moves at all, adjust as needed.
Old Feb 6, 2008 | 06:10 PM
GSTDA9's Avatar
nope i tryed it my screw is all the way closed and the idle is still high
Old Feb 7, 2008 | 03:59 PM
efyou's Avatar
can u post a pic of your vacuum hoses? maybe ones going to the wrong place
dc4b20
22
Dec 3, 2012 09:54 PM
UNKNOWN_MEMBER
Aug 11, 2005 08:55 PM
mrx
Jun 25, 2005 08:01 AM
Civic Racer X 7
Jul 23, 2003 07:19 AM
dingusjt
May 12, 2003 10:39 AM
