Custom 1 Peice wiring for h22 into EG Troubles/ideas ......
Old Feb 4, 2008 | 02:34 PM
likwidchz's Avatar
Default Custom 1 Peice wiring for h22 into EG Troubles/ideas ......
So basically guys/gals heres what I did
took the stock D18b8 lawnmower engine harness and took the stock H22A harness from hmo motors "awesome place btw" and used the ends/injector clips and best connectors from each engine to remake a 1 piece wire harness.
Every wire from the engine goes to the ecu "Connectors A B D"
wires that go from the dash to the sensors are also redone
I guess what I'm asking is I have a printout as you can see in one of my photos of the wiring diagram and ECU pins they go to..
I am wondering if anyone has done this before? and
granted there are a lot of options i did not hook up
Ill start from the top pin outs
A12 condenser fan relay
A15 ac clutch relay
A17 IAB solenoid
A18 FAS (A/T)
A19 Intake Control Solenoid valve
A20 Evap purge
B3/B4 (A/T) bullshit
B5 A/C Switch
B7 AT gear postion switch
B8 PSP Switch
D2 -- Brake switch I have no idea what this is suppose to do, but its hooked up.
D10 -- ELD -- this was pinned but the CX dosent have ELD SO its not connected
D12 - EGR LIFT
D19 EGR Valve lift sensor
As noted all above are not connected, does anyone have any idea why the fuel pump doesn't come on?
the MIL pin from the dash goes directly to the ECU as I identified this pin out from the wiring diagram.
the engine turns over, the mil stays on, the battery light flashes as its cranking and thats about it!
I am going to wire the fuel pump on when the key is put in to test to see if its an issue with that "crosses fingers"
If there are any wiring gurus out there I would like to know if i missed something hooked up or needs to be grounded or what i can do!
--Thanks again Photos of my headache are below.
--Aaron
Old Feb 4, 2008 | 02:54 PM
saywhat's Avatar
Default Re: Custom 1 Peice wiring for h22 into EG Troubles/ideas ...... (likwidchz)
I have to give you points for getting this far. Did you check the main relay? That is all I've got. sorry...
Old Feb 4, 2008 | 03:08 PM
likwidchz's Avatar
Default Re: Custom 1 Peice wiring for h22 into EG Troubles/ideas ...... (saywhat)
yeah main relay is been checked , frankly i think the main relay is gay and needs to be replaced with 2 normal off the shelf relays like they do in the race cars...
I will check it again but the main relay was putting out voltage where voltage was suppose to be put out... ill give it another try tommrow.. anyone else?
Old Feb 4, 2008 | 03:18 PM
saywhat's Avatar
Yeah, plus the main relay wouldn't normally trip the CEL/MIL if it were to go out. I am stumped, I assumed you have checked continuity at the actual pump?
Old Feb 4, 2008 | 03:59 PM
likwidchz's Avatar
No, although i do remember the 1st time i tried making a harness it failed but i did wire the fuel pump differenty just to test, ill try that again though...
anyone else ??? a wiring expert here??
Old Feb 4, 2008 | 05:11 PM
ejoner's Avatar
Default Re: (likwidchz)
I say just rewire the pump so it goes on with the ignition. Do you hear the relay click?
Old Feb 4, 2008 | 05:23 PM
likwidchz's Avatar
yeah relay clicks,
but thats a good point i should just rewire that **** so its not ecu controlled..
Old Feb 4, 2008 | 06:38 PM
likwidchz's Avatar
Still needing to know if anyone has done this before? 1 piece wiring h22 into eg??
Old Feb 5, 2008 | 09:17 AM
likwidchz's Avatar
Bump --- speedBUMPs --- how many BUMPs does it take to get to the center of a speed BUMP --- BUMPtastic... anyone??
Old Feb 5, 2008 | 03:18 PM
saywhat's Avatar
Are you getting 12v to the pump connection with ignition on, or not? Do you have another ECU you can use to see if the other one is buggy or something?
Old Feb 5, 2008 | 04:57 PM
likwidchz's Avatar
Yea.. 12v is not going to the fuel pump, i need to take a look at that tommrow and figure out what i cut, but I would like to have it perform as oem 2 seconds on when key is in ignition spot 2, i need to find the page in the service manual that identifys wire color's and test it all..
--thanks ill post tommrow sometime.
Old Feb 6, 2008 | 01:46 PM
likwidchz's Avatar
quickly wired the fuel pump to the acc position, fuel pump comes on, although the CEL light is on solid, the jumper switch that i installed to make it flash the cel code doesn't do anything.
any ideas?
Old Feb 7, 2008 | 02:06 PM
likwidchz's Avatar
any ideas?
Old Feb 7, 2008 | 04:43 PM
ejoner's Avatar
Did you try starting the car? I don't know man all I could tell you it go over all your wiring, and make sure the ecu your working with is not at fault.
Old Feb 8, 2008 | 04:06 PM
likwidchz's Avatar
HEHE silly OFcourse I tried starting the car.
Either way, PROBLEM = SOLVED
expletiveING one happy guy! right now,
Pin A26 was not even connected and it should have been grounded ! thats it!
Previously the CEL light would not go out.
Below are some photos of my car and the thing i was working on,
The A, B, D connectors will get tided up pretty soon with a whole bunch of small zip ties to make it look less then ***, but either way, the beast is alive!
usdmftw
Jul 4, 2011 11:25 AM
AyOhOndA
Dec 8, 2010 03:00 PM
JDM_SOHC
Apr 12, 2009 02:57 PM
Malgerus
Jul 13, 2008 10:34 AM
Honda4CX-T
May 15, 2002 03:27 PM
