GSR won't start (no CEL, no ignition)
Old Feb 4, 2008 | 01:47 PM
chris.deyoung's Avatar
Default GSR won't start (no CEL, no ignition)
Hi guys, i just finished a GSR swap into my 2000 DX hatchback. When I turn the key, the check engine light does NOT come on with the fuel pump like it normally did with the D16y7's ecu. Pulled the plugs yesterday, and found that the motor was getting spark and fuel...today when I actually went to start it for the first time, it was not getting any ignition. The fuse is alright, and theres power getting to the dizzy clip.
I haven't wired the VTM or VTS to the computer yet, but that shouldn't make any difference...that and I didn't put a knock sensor in it yet.
Could this simply be a bad ECU? (OBD1...and I am running a conversion harness)
Can I try using the D16y7 ECU to see if it will start, or will that not work?
Hope this thing runs soon, thanks for any help.
Old Feb 5, 2008 | 01:03 AM
BlakeJ53's Avatar
Default Re: GSR won't start (chris.deyoung)
Do you have enuogh grounds? Or loose grounds?
BlitzSix
Aug 25, 2010 11:52 PM
chris.deyoung
Feb 12, 2008 05:52 PM
Lucky-13
Mar 23, 2007 09:33 PM
lude97dude
Jan 21, 2003 08:53 PM
