Wish i had signal lights!! need help
Old Feb 4, 2008 | 12:42 PM
HondaKid936's Avatar
Default Wish i had signal lights!! need help
so i traded cars and i jus rebuilt the motor blah blah the car has an integra dash but the signal lights dont work i mean the EMERGENCY blinkers work but not the signal lights ? i hear no click when i flick left or right blinker but the front lights work? lmk if u have any info for me thankz HONDA TECH
car is a eg 94 ex will take pics of under dash if needed to explain better
Old Feb 4, 2008 | 12:53 PM
hgem1si's Avatar
Default Re: Wish i had signal lights!! need help (HondaKid936)
Did you check the fuse? The flasher?
Old Feb 4, 2008 | 05:52 PM
Default Re: Wish i had signal lights!! need help (hgem1si)
well ive cheked most fuses and most are good i dont have the map cover that tells me wat fuse is what DOES SOMEONE HAVE A PIC OF THEY'RE FUSES!!!!
Old Feb 5, 2008 | 03:54 PM
GSR_hatch936's Avatar
still cant get it fixed?
Old Feb 5, 2008 | 03:59 PM
Dramier's Avatar
Default Re: Wish i had signal lights!! need help (GSR_hatch936)
South-east Texas? Houston or what?
Where you at?
I might help if you're close by..
Old Feb 5, 2008 | 06:16 PM
Default Re: Wish i had signal lights!! need help (Dramier)
lol dude im from lufkin too who are you?
Old Feb 10, 2008 | 11:59 PM
so my dash is off a DC what could cause my blinker switch not to even click BUT MY EMERGENCY LIGHTS WORK they click in the cluster!!!! someone help please i help others but get no help peace
Old Feb 11, 2008 | 12:39 AM
JarvisW's Avatar
Sol to Sol
Lol, I used to go to SFA!
Dallas now, but I miss the piney woods.
Just thought I'd say hi lol.
Old Feb 11, 2008 | 12:17 PM
Default Re: Wish i had signal lights!! need help (JarvisW)
bump thats cool man but some one know electrical??? anyone know what might be my problemo?
Old Feb 11, 2008 | 12:21 PM
B16B_coupe's Avatar
HRD PKR
Your switch could be bad, Blown fuse, Or not even plugged in.
Old Feb 11, 2008 | 02:25 PM
Yell0w's Avatar
Default Re: Wish i had signal lights!! need help (B16B_coupe)
you need to tap one to many of the wire from under the dash to a different harness. when i get home i will post later which wire goes where.
Old Feb 11, 2008 | 03:22 PM
aziaticvang's Avatar
does your car have a clock? because i had the same problem and happen to figure out that i plugged the wrong harness which was for the clock into the hazard light switch and made my signals not work and but hazard worked.
Old Feb 12, 2008 | 12:06 AM
Default Re: Wish i had signal lights!! need help (Yell0w)
i would really apreciate that man, and about the clock could be right cuz i mean the clock jus turns on but i cant set time?? did u have the same problem aswell? well i guess rip apart the dash?
Old Feb 12, 2008 | 11:11 AM
blk92_d16's Avatar
Sounds like maybe a swapped connector there, but if not...my thought was the actual signal combo switch.
brookesmommy21
Nov 16, 2014 05:43 AM
92honda92
Sep 27, 2007 07:48 AM
vietfella
Mar 12, 2007 09:23 PM
mel
12
Nov 9, 2006 09:04 AM
