Wish i had signal lights!! need help
so i traded cars and i jus rebuilt the motor blah blah the car has an integra dash but the signal lights dont work i mean the EMERGENCY blinkers work but not the signal lights ? i hear no click when i flick left or right blinker but the front lights work? lmk if u have any info for me thankz HONDA TECH
car is a eg 94 ex will take pics of under dash if needed to explain better
Re: Wish i had signal lights!! need help (hgem1si)
well ive cheked most fuses and most are good i dont have the map cover that tells me wat fuse is what DOES SOMEONE HAVE A PIC OF THEY'RE FUSES!!!!
Re: Wish i had signal lights!! need help (HondaKid936)
so my dash is off a DC what could cause my blinker switch not to even click BUT MY EMERGENCY LIGHTS WORK they click in the cluster!!!! someone help please i help others but get no help peace
Re: Wish i had signal lights!! need help (B16B_coupe)
you need to tap one to many of the wire from under the dash to a different harness. when i get home i will post later which wire goes where.
does your car have a clock? because i had the same problem and happen to figure out that i plugged the wrong harness which was for the clock into the hazard light switch and made my signals not work and but hazard worked.
Re: Wish i had signal lights!! need help (Yell0w)
i would really apreciate that man, and about the clock could be right cuz i mean the clock jus turns on but i cant set time?? did u have the same problem aswell? well i guess rip apart the dash?
brookesmommy21
11-16-2014 05:43 AM
vietfella
03-12-2007 09:23 PM
