what kind of turbo should i run on semi built ls
Old Feb 3, 2008 | 09:31 PM
rEdLiNeObSeSsOr's Avatar
Default what kind of turbo should i run on semi built ls
ok im looking to turbo my ls im about to drop in my 91 crx si. i ws wondering what turbo setup i should run on a semi built ls with new rods pistons some head work and block guards. any suggestions are welcome
Old Feb 3, 2008 | 09:35 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: what kind of turbo should i run on semi built ls (rEdLiNeObSeSsOr)
goals, what exactly semi built means budget ehhh none of that matters.
You are here for a band wagon reply, I shall not grant this request.
Sadly, I enjoy being useful and helping people and teaching them.
So I will ask you to list those things and any ideas what this car may be used for and any other changes that might happen so I can give you a more worth while response.
Old Feb 4, 2008 | 01:36 PM
ummm block guard some head work pistons rods want to spend no more than 600 for turbo and intercooler waste gate blow off. anyways just want to know what the average crx with semi built ls is running for a turbo not a challenging question.
Old Feb 4, 2008 | 01:50 PM
Ass$nyper's Avatar
Default Re: (rEdLiNeObSeSsOr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rEdLiNeObSeSsOr &raquo;</TD></TR><TR><TD CLASS="quote">ummm block guard some head work pistons rods want to spend no more than 600 for turbo and intercooler waste gate blow off. anyways just want to know what the average crx with semi built ls is running for a turbo not a challenging question.</TD></TR></TABLE> It is a hard question as there are 1000s of different turbines out there.
I still have no clue what your comp ratio is what kind of rods you have or anything about your build other then a few parts named.
You won't get far with 600 at least with anything good.
Old Feb 4, 2008 | 02:19 PM
KickStart2323's Avatar
Default Re: (***$nyper)
from what i have seen and read most people use a t3 or a t3/t4 hybrid, but like any hypothetical question you will get a hypothetical answer....if you check out http://www.homemadeturbo.com you will find alot...
SlowCRX Si
Nov 20, 2011 09:16 PM
g0tgot
Oct 9, 2008 04:55 AM
hiphop23j
Nov 10, 2007 06:59 PM
00CivicGirl
Jul 4, 2005 08:23 PM
2 point 0
Apr 22, 2004 03:11 PM
