usdm d16z6 vs. jdm zc sohc vtec?
Old Feb 3, 2008 | 03:56 PM
DCSportEJ1Civic's Avatar
Default usdm d16z6 vs. jdm zc sohc vtec?
what if any are the differences between a USDM D16Z6 and the JDM ZC SOHC VTEC? im looking for a temporary replacement motor and am trying to stay away from a junk yard. but im having trouble finding a usdm motor.
Old Feb 3, 2008 | 04:01 PM
z6hatchboy's Avatar
Default Re: usdm d16z6 vs. jdm zc sohc vtec? (DCSportEJ1Civic)
The jdm zc sohc (d15b) has like 3-5 more hp than the usdm d16z6. It comes from the bump in the c/r. Thats the only diff i believe. Not too mention everyone thats always asking what water pump do i get for my d15b and all the other q's along with d15b's like that.
Old Feb 3, 2008 | 04:51 PM
Default Re: usdm d16z6 vs. jdm zc sohc vtec? (z6hatchboy)
well all the zc's ive been seeing on websites are listed as a 1.6 liter. id rather just have the d16z6 myself.
Old Feb 3, 2008 | 04:52 PM
z6hatchboy's Avatar
Im happy with my z6, and if your wanting just a temp replacement, it would be cheaper.
Old Feb 3, 2008 | 05:00 PM
yea, i just want to fix it and drive it. i blew it up and bought a newer hatch but now im in school and if it wasnt for my car payment on the car i absolutely hate (lol) i could pay for school out of my pocket. so basically im trying to avoid as much problems as possible by finding something to just drop in. but no one sells a USDM z6. and i would rather not have a junk yard motor. what a predicament.
Old Feb 4, 2008 | 08:53 AM
Panda Eg6's Avatar
yea the Jdm soch vtec ZC motor is actually a 1.6 and not the same as the d15b, it is identical to the z6 usdm motor.
Old Feb 4, 2008 | 09:09 AM
mortificationrock's Avatar
Default Re: usdm d16z6 vs. jdm zc sohc vtec? (Panda Eg6)
Correct me if im wrong,but isn't the JDM Sohc ZC a Dohc D series from what I remember.
And no a D15B is not a ZC
Old Feb 4, 2008 | 09:38 AM
Panda Eg6's Avatar
Default Re: usdm d16z6 vs. jdm zc sohc vtec? (mortificationrock)
Yea there is a dohc ZC also. They were talking about the sohc vtec ZC
Old Feb 4, 2008 | 10:02 AM
would it directly replace the z6 then? is the ecu diff. can i run my p28. out of curiosity are the injectors bigger? and what problems do i run with a jdm motor? sensor diff or anything? (its my first import motor swap lol)
Old Feb 4, 2008 | 10:08 AM
Panda Eg6's Avatar
Im sure you could run your P28. Not sure on the sensors since its a JDM motor. I have a JDM type R and it has less things than the USDM version does.
Old Feb 4, 2008 | 10:29 AM
well i guess i could just swap my intake mani right?
Old Jan 4, 2009 | 06:57 PM
ron212002's Avatar
bump
I would like to know if I could just swap in a zc with my old tranny to . I have the d16z6 in a 94 civic also . Would like to just replace the motor and use the old ecu and tranny . Is it possible ?
Old Jan 4, 2009 | 08:07 PM
95vxtealhatch's Avatar
Yes it is, every d-series tranny is swappable with no modifications
Old Jan 5, 2009 | 11:27 AM
SleepstR88's Avatar
The zc vtec is basically a z6. The p28 and trans will work without issues.
Old Jan 5, 2009 | 12:59 PM
94EG8's Avatar
Seagull Management
yeah, pretty much, the only difference I can think of is the ZC doesn't have a purge solenoid on the back of the intake manifold, you can either swap your old D16Z6 manifold on (its 100% identical otherwise) or add the purge solenoid to the back of the intake manifold.
Old Jan 5, 2009 | 02:41 PM
Evs-One's Avatar
Solbros Owns Me
ZC SOHC VTEC engines have P28 stamped all over the parts- intake mani, pistons, etc.
I'm not sure about cam profile, but everything else is identical to D16Z6.
Why even post when you can't even comprehend what the original question is?
phoQ
22
Nov 11, 2021 07:59 PM
skaternak
Sep 29, 2009 08:19 AM
BryanLavo
17
Feb 15, 2007 08:07 AM
vxnine
32
Oct 20, 2004 03:47 AM
tolowhb
May 13, 2003 04:01 PM
