tranny swap trouble... need help quick.
Old Feb 3, 2008 | 01:49 AM
94c1v1cex's Avatar
Default tranny swap trouble... need help quick.
so boost killed my z6 tranny that i had mounted to the d15b... i got ahold of a y8 trans that had been checked out by a transmision shop and is said to be in great condition...
swaped the y8 trans in and now when i started the car it made a weird noise. it is very hard to put into gear even when the car is off. also when the car is off and i put it in gear it still rolls like it is in neutral. when i start the car and start to let the clutch out the vss starts going up but the car doesnt go anywhere and it makes another weirdnoise. i push the clutch back in and the vss still stays where it is and the noise continues until i turn the ignition off. help!!!! need it fixed soon its my daily.
Old Feb 3, 2008 | 06:17 AM
SiREJ8's Avatar
Default Re: tranny swap trouble... need help quick. (94c1v1cex)
check the axles that they are fully seated...
Old Feb 3, 2008 | 06:22 AM
95dxsir2's Avatar
Default Re: tranny swap trouble... need help quick. (SiREJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiREJ8 &raquo;</TD></TR><TR><TD CLASS="quote">check the axles that they are fully seated...</TD></TR></TABLE>
Old Feb 3, 2008 | 09:28 AM
94c1v1cex's Avatar
Default Re: tranny swap trouble... need help quick. (95dxsir2)
but why ould it be so hard to get in gear and why would the vss still go up wen it is still in neutral?
Old Feb 3, 2008 | 11:32 AM
94c1v1cex's Avatar
love to get this done before the superbowl
Old Feb 3, 2008 | 11:37 AM
civicxpress's Avatar
sounds like the wrong clutch, or alighment
Old Feb 3, 2008 | 11:51 AM
z6hatchboy's Avatar
The reason it could be hard to put into gear is, does it have enough fluid (motor oil) in the tranny? The reason the vss is moving is because the tranny is, however if your exles are not installed/seated correctly the tranny power/movement will not make to the wheels.
Old Feb 3, 2008 | 06:27 PM
94c1v1cex's Avatar
Default Re: tranny swap trouble... need help quick. (z6hatchboy)
axles are seated and they spin the rotors with the car jacked up in gear. it just makes this weird chatter noise like the cluth disc is floppin around in there.
Old Feb 4, 2008 | 03:54 PM
what was it? i still think u got the wrong throw out bearing or the wrong clutch
runthatboost
Jan 6, 2007 04:51 PM
BlackYoshi
Nov 3, 2005 03:53 PM
