please help
Old Feb 2, 2008 | 06:25 PM
one-cam's Avatar
Default please help
hello all, i own a 88 crx with a y7. other day i was changing spark plugs and i accidently crack the plug in one cylinder. i took the head off and this is how it looks like after we tried to unscrew it. any help on how to get it out would be nice. theres a performance shop that does this here but they will charge me alot
Modified by one-cam at 8:39 PM 2/2/2008
Old Feb 2, 2008 | 06:41 PM
traxxasx's Avatar
You best bet would be to drill it out. Get a bit just about the inside diameter of the plug, drill it from the vavles out, just like in the pic. Push real hard and it should screw its self out. Also spark plugs only need to be a little more than snug tight.
Old Feb 2, 2008 | 06:42 PM
ridgeapd's Avatar
screw it.
seriously.
Ideally get a reverse bit drill bit that comes in an extractor set and do it to it.
OR, maybe get your drill and small drill bit and drill out the middle. then step up to a larger drill bit. Eventually you ought to be able to free it out.
I'm just throwing out ideas. If you drill, please be careful not to drill into the head, or threads of the plug hole. it would be a pain in the ***.
Old Feb 2, 2008 | 06:48 PM
one-cam's Avatar
Default Re: (ridgeapd)
thanks to both of you ill try the drill right now
Old Feb 2, 2008 | 06:51 PM
deadmemoryy's Avatar
Default Re: (one-cam)
off subject but you should seafoam when your all done did you crack that piece inbetween the valve and the plug? it looks like it in the first picture...
Old Feb 2, 2008 | 06:52 PM
ridgeapd's Avatar
Take pictures after its out! post them asap.
Old Feb 2, 2008 | 07:51 PM
one-cam's Avatar
well i tried that idea and now i have 6 broken drill bits on the side.. and by the way deadmemoryy no i accidentaly (again) scratched that with the screwdriver
i will take pictures right after i come back from napa with the reverse drill bit
Old Feb 3, 2008 | 12:00 AM
traxxasx's Avatar
You need a real hard bit not regular bits.
Also use lots of lube and take a torch to it for a bit.
Old Feb 3, 2008 | 05:08 AM
fireant's Avatar
Default Re: (traxxasx)
Is the chamber cracked in the first pic? If so, you might need a new head.
My personal experience with extractors is unless the conditions are perfect for you to get the hole and bit perefectly straight, it will break off in there, leaving a very hard core embedded in your stuck plug.
Two other ways to extract it:
1. use a fine-tip dremel or a very small cutoff wheel to make a flathead slot in the plug.. just be careful not to slot the chamber too, I dont think JB weld patches will hold up inside there.
or
2. make two small holes across from each other on the broken plug, then insert a needle-nose plyer tip into each hole and unscrew it. Be sure to use a punch to make precise guide holes before drilling, so you dont accidentally drill into the threads on the head.
Whatever you do, be patient and let us know what happens. Good luck!
Old Feb 3, 2008 | 07:53 AM
nihad's Avatar
Default Re: (fireant)
Looks like it is cracked and i sell u one of my heads for 50$
Old Feb 3, 2008 | 05:42 PM
one-cam's Avatar
bought this..
<br/>
the one missing is the one i will use but i dont have my impact gun. i will post pictures tomorow when i try to get it off with the reverse bit
thanks for ur help
RecklessEJ
Apr 30, 2012 08:13 PM
Dan@DFR
Jan 29, 2012 04:32 PM
h22 kid
Oct 24, 2009 12:10 AM
DeviousCTR
Oct 17, 2007 07:54 AM
Layziebtnh055
Apr 8, 2004 02:41 PM
