rear main seal question..
Old Feb 2, 2008 | 04:38 PM
GSR_hatch936's Avatar
Default rear main seal question..
i just removed my tranny for the 2nd time with in 2 months cuz of an oil like and i didnt put sealant around the seal... should i put sealant around it.. cuz i know the crank turns and if i put sealant it will just brake but should i put it around the outside of the seal?? and theres a bolt on the block should i tighting it and i think there's another seal behind the rear main seal.. sorry if u can understand im tryin to type fast cuz i want to finish tonight.!
Old Feb 2, 2008 | 05:25 PM
Default Re: rear main seal question.. (GSR_hatch936)
here's a pic of the seal i put gasket sealant around the outside of the gasket but not around the crank.... bad idea?? and that bolt to the uper left i was just checking to see if it was lose and u got a pair of vise grips and clemp it down and turned it left and it was lose.... so i tighting it as hard as i can but the vise grips just slip off hopyfully its tight enough cuz i dont got a allen wrench for it.. btw what size allen is it??
Modified by GSR_hatch936 at 11:11 PM 2/2/2008
Old Feb 2, 2008 | 05:33 PM
z6hatchboy's Avatar
Dont put any kind of sealant on or in the rear main seal itself, just use honda-bond or the gasket that came with it to seal metal casing that bolts to the block.
Old Feb 2, 2008 | 06:37 PM
95vxtealhatch's Avatar
just get another rear main, they are cheap. Do it the right way.
Old Feb 2, 2008 | 07:07 PM
postman's Avatar
Default Re: (95vxtealhatch)
are you sure the seal is whats leaking
Old Feb 2, 2008 | 08:12 PM
Default Re: (postman)
Like i said the seal was new replaced it like 2 months ago and just making sure it wasnt it cuz my car still was leaking oil. and i already put the sealant on the gasket should i just remove it again and take off the sealant?
Modified by GSR_hatch936 at 11:52 PM 2/2/2008
Old Feb 2, 2008 | 10:56 PM
boosted_dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR_hatch936 &raquo;</TD></TR><TR><TD CLASS="quote">here's a pic of the seal i put gasket sealant around the outside of the gasket but not around the crank.... bad idea?? and that bolt to the uper left i was just checking to see if it was lose and u got a pair of vise grips and clemp it down and turned it left and it was lose.... so i tighting it as hard as i can but the vise grips just slip off hopyfully its tight enough cuz i dont got a allen wrench for it.. btw what size allen is it??
Modified by GSR_hatch936 at 11:11 PM 2/2/2008</TD></TR></TABLE>
dont use vise grips for christs sake, get the right tool. and look up torque specs, dont "tighten it as hard as you can" i mean if you want to do it right just keep tightening it until the bolt turns easy.
Landon
Old Feb 3, 2008 | 08:17 AM
Default Re: rear main seal question.. (boosted_dc2)
well the bolt was lose before i even started to tigthen it so i figured ill just tight it with the vise grips...... do u even know what tool that is?? and i pretty sure the specs on that big *** bolt is like 80-90 ft/lbs.... alot of pressure dude.. but i will look up the specs and get the tool. but i think the vise grips did the job.. Im mainly conserned with the rear main seal cuz i aready put sealant last night and was hoping that it wouldnt hurt it...
Modified by GSR_hatch936 at 11:33 AM 2/3/2008
Old Feb 3, 2008 | 11:25 AM
what do you think sealant will do around a rotating part rotating 7,000 RPM's? do you really think thats the answer to your problem?
Landon
deeboi
Jan 21, 2013 10:25 PM
drsab2000
Nov 3, 2012 08:05 PM
zrs6v4
Oct 14, 2009 09:52 AM
JCracer723
12
Jun 13, 2003 12:14 PM
GSRwBOOST
Jul 7, 2001 09:15 PM
