What a good gun to spray with??
Well I think Id like to dabble into painting. I have an old toolbox that needs some love so I can practice on it. I already have a compressor so I just need a good quality gun for a decent price.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrapunk67 »</TD></TR><TR><TD CLASS="quote">For the ~$100 range the Sharpe FX3000 series or the Devilbiss Finishline are pretty decent guns.</TD></TR></TABLE>
decent very very low end gun, yes they are.
i will not spray anything cheaper than finishline, but that would be just me.
not sure which one is the fx3000 the cheapest walmart like sharpe has some crappy nozzle and air pattern.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicman86 »</TD></TR><TR><TD CLASS="quote">Well I think Id like to dabble into painting. I have an old toolbox that needs some love so I can practice on it. I already have a compressor so I just need a good quality gun for a decent price.
price range, what kinda paint?, what size is teh compressor?
decent price doesnt mean anything
I want a good gun for a good price. Actual price I would say under 300. Basically what gun out there is the best bang for the buck.
Compressor is a 60gallon.
I have no idea what kind of paint. Most stuff would probably be car parts.
Honestly I have alot of research to do on this subject, before I buy the gun. But I figure its a good start.
While we are at it:
What makes one good better than another, besides build quality?
While we are at it:
Better atomization and less air usage.
Good gun around 300 with your compressor?
You can find used Sata's around that range. Also if you up your budget a little more Iwata LPH400's aren't that far off.
Then get a cheap Astro primer gun and you're all set. The Iwata lays clear like a dream! Though I'm not that much of a Sata fan. They're heavy and use too much air for my liking.
The FX3000 just came out which is probably why you haven't heard of it.
If you could find a used Iwata LPH-400 I'd pick one of them up. Otherwise a used Sata NR 2000 or 3000 wouldn't be bad though I wouldn't go digital.
Devilbiss has a number of guns in the $230ish range that are pretty good.
its all in a matter of opinion . ive seen the cheap guns throw down great paint jobs . getting a nice paint job is 50% the gun and 50% is the person spraying it . the proper technique plays a huge part in a good paint job . do some research on this as well . ive never heard anything good about pressure fed guns . so id say stick with gravity fed . also your going to need different tips for the gun , that shoot primer , paint and clearcoat . and always give the gun a meticulous cleaning .
No need for 3 guns, thats redic for a first time painter. A single HVLP such as a used saTA is more than fine for priming and painting with different tips.
Anyway its not the size of the tank, but the cfm that matters, if your compressor can't keep up it is constantly going to be on and possibly causing pressure drops causing orange peel, uneven spray etc.
look on autobody101 about equipment information.
Those are the ratings on the side of the tank...
13.3 SCFM @ 90PSI
15.0 SCFM @ 40PSI
135PSI max
Good for painting?
2'z kuztoms: I'll keep you in mind. You looking to sell ti soon? I'd like to do a little research before jumping in. I am a ultra noob when it comes to painting so I have ALOT to learn.
Thanks for the comments guys, its appreciated.
13.3 SCFM @ 90PSI
15.0 SCFM @ 40PSI
135PSI max
Good for painting?
iwata
this is the gun i use at autobody school and it kicks ***... make sure u get the orange cap for base and the silver cap for clear coat. set it to 16lbs in the inlet so you get 10psi at the cap makes for perfect sprays. any questions pm me.
From: Streets of Sacramento...But now living in So Cal, usa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicman86 »</TD></TR><TR><TD CLASS="quote">Those are the ratings on the side of the tank...
13.3 SCFM @ 90PSI
15.0 SCFM @ 40PSI
135PSI max
Good for painting?
Thanks for the comments guys, its appreciated. </TD></TR></TABLE>
im not in a rush to sell im just throwing this one out there i have 7 other guns (2 iwata, 3 sata, 1 transtar, and 1 upol). i just prefer the iwata if your spraying at home or outside
13.3 SCFM @ 90PSI
15.0 SCFM @ 40PSI
135PSI max
Good for painting?
13.3 SCFM @ 90PSI
15.0 SCFM @ 40PSI
135PSI max
Good for painting?
it's border line but you are fine.
let me guess 60 gallon 240v single stage?
i think my sata runs 14cfm at 40
13.3 SCFM @ 90PSI
15.0 SCFM @ 40PSI
135PSI max
Good for painting?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2’z kuztoms »</TD></TR><TR><TD CLASS="quote">
im not in a rush to sell im just throwing this one out there i have 7 other guns (2 iwata, 3 sata, 1 transtar, and 1 upol). i just prefer the iwata if your spraying at home or outside</TD></TR></TABLE>
Alright cool, Ill definitely keep in touch.
Thanks again everyone for the help. I'm sure I will have more noob questions soon.
