Manual rack conversion EK
Hey guys, quick question. Im able to get a manual rack from an ek cx to install into my ek which has p/s. Will i need the cx sub frame like you require if your doing the p/s to manual on the eg's? or on ek's the rack will just bolt up to the subframe??
thanks!
thanks!
I'm also looking for this answer. In the mean time, here's an interesting thread about converting power to manual: https://honda-tech.com/zerothread?id=184202
well heres the deal im getting a rebuilt one...no idea y u would need to rebuild a manual rack haha but either way im getting a rebuilt one through work so it should come with everything i need except subframe...so on EK's u dont need the subframe?
Why are you replacing the rack? Why not just do a delete kit? The 96-00 power steering rack is shorter stop to stop, and gives more steering response (less turns of the wheel for more turn of the car).
i still havent received a perfect answer as to if i need the subframe or not....cause i can get the rack tommorow but i need to know for sure if i need the subframe or not...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jord18 »</TD></TR><TR><TD CLASS="quote">i still havent received a perfect answer as to if i need the subframe or not....cause i can get the rack tommorow but i need to know for sure if i need the subframe or not...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o2flow.net »</TD></TR><TR><TD CLASS="quote">no, but you'll need the bracket from the manual rack as the PS bracket is slightly larger</TD></TR></TABLE>
What else do you want?
Weifast
Nov 1, 2009 07:26 PM
o2flow.net
32
May 16, 2006 08:10 AM
