Manual rack conversion EK
Hey guys, quick question. Im able to get a manual rack from an ek cx to install into my ek which has p/s. Will i need the cx sub frame like you require if your doing the p/s to manual on the eg's? or on ek's the rack will just bolt up to the subframe??
thanks!
thanks!
Re: Manual rack conversion EK (jord18)
I'm also looking for this answer. In the mean time, here's an interesting thread about converting power to manual: https://honda-tech.com/zerothread?id=184202
well heres the deal im getting a rebuilt one...no idea y u would need to rebuild a manual rack haha but either way im getting a rebuilt one through work so it should come with everything i need except subframe...so on EK's u dont need the subframe?
HT White Ops
Why are you replacing the rack? Why not just do a delete kit? The 96-00 power steering rack is shorter stop to stop, and gives more steering response (less turns of the wheel for more turn of the car).
Re: (Eran)
i still havent received a perfect answer as to if i need the subframe or not....cause i can get the rack tommorow but i need to know for sure if i need the subframe or not...
Re: (o2flow.net)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jord18 »</TD></TR><TR><TD CLASS="quote">i still havent received a perfect answer as to if i need the subframe or not....cause i can get the rack tommorow but i need to know for sure if i need the subframe or not...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o2flow.net »</TD></TR><TR><TD CLASS="quote">no, but you'll need the bracket from the manual rack as the PS bracket is slightly larger</TD></TR></TABLE>
What else do you want?
Weifast
11-01-2009 07:26 PM
o2flow.net
32
05-16-2006 08:10 AM
