5th gen 5spd swap (4th gen parts???) searched!!!!!!
Old Feb 2, 2008 | 06:31 AM
preludejayes's Avatar
Default 5th gen 5spd swap (4th gen parts???) searched!!!!!!
ok well im getting the 5spd swap parts....now my question is what 4th gen parts are interchangeable with a 5th gen??
Transmission -(M2S4 h23 TRANNY is what im going with i know this fits)
Trans mounts-side -(has to be from a 5th gen)
Flywheel and bolts -
Clutch Kit and bolts -
Clutch Master Cylinder -
Clutch Slave Cylinder -
Clutch Dampener – (I think this comes with the clutch?)
Vehicle Speed Sensor (VSS)-
Reverse Switch
Hydraulic Lines
5spd Starter-got it
Clutch Pedal Assembly
Brake Pedal Assembly
Shifter Assembly
Shift linkage
5speed ECU
5spd Intermediate shaft (half-shaft)
5spd Axles
Shifter Boot-
Shifter ****
i stated what parts have to come from a 5th gen...when i searched i got this...
https://honda-tech.com/zerothread?id=1428516
there was a debate about the shifter linkage...anyone know for sure??
Old Feb 2, 2008 | 07:10 AM
98vtec's Avatar
moderator emeritus
Default Re: 5th gen 5spd swap (4th gen parts???) searched!!!!!! (preludejayes)
you can use 4th gen shift linkage as long as you use the 4th gen shifter plate and shifter.
Old Feb 2, 2008 | 08:00 AM
Thanks, and everything else should also fit right?
kornerk12
Feb 16, 2007 12:44 PM
hamadiscool
Dec 13, 2006 10:37 PM
flight50
Jul 13, 2005 10:19 AM
ItalynStylion
Nov 13, 2004 02:32 PM
EM2Civic
Oct 4, 2004 10:24 AM
