is ok to run a walbro 255 lph pump on a stock setup?
Old Jan 31, 2008 | 08:52 PM
be18see1's Avatar
Default is ok to run a walbro 255 lph pump on a stock setup?
is it? will it run at a ridiculous pressure, thus requiring i purchase a fuel pressure reg.. before the why questions, i intend to go turbo and just wanted to know if i can throw the pump on now or if i should wait.
Old Feb 1, 2008 | 12:45 AM
StorminMatt's Avatar
Default Re: is ok to run a walbro 255 lph pump on a stock setup? (be18see1)
If you are going to be running a pump with this kind of capacity, you need to upgrade your fuel pressure regulator. Otherwise, the engine will run REALLY rich, especially at low RPMs.
Old Feb 1, 2008 | 07:13 AM
be18see1's Avatar
Default Re: is ok to run a walbro 255 lph pump on a stock setup? (StorminMatt)
oh ok. if i wait until i have 450cc injectors and a turbo spooling on the other end i wont need to buy a fpr, right?
Old Feb 1, 2008 | 12:41 PM
97grnrs's Avatar
u can run it and be fine. it may be about 50 psi at idle but it aint gonna hurt anything. u can always drill the tiny hole in the stock reg and let some of the press bleed out. theoldone.com has it.
Charlie Moua
21
Feb 11, 2011 05:54 AM
CFDOHCVTECEG
Feb 2, 2007 03:32 PM
M.K.C.
Nov 17, 2003 10:43 AM
Anubyss
Apr 23, 2003 06:54 AM
Smoothy
Oct 6, 2001 06:48 AM
