Slight pulsating in brake pedal..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ******* »</TD></TR><TR><TD CLASS="quote">did you replace the pads too?</TD></TR></TABLE>
yep
yep
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T3k C »</TD></TR><TR><TD CLASS="quote">Check caliper pistons, are the floating pins lubed? </TD></TR></TABLE>
Why would it matter if the floating pins are lubed? He's on the brakes when he feels the pulse not when off the brakes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi »</TD></TR><TR><TD CLASS="quote">
Why would it matter if the floating pins are lubed? He's on the brakes when he feels the pulse not when off the brakes.</TD></TR></TABLE>
Yeah just when I slow down it pulses a little. I thought it was the rotors since the last set were cut to give me a little more time, but they were all replaced along with the brake pads. Could it be a through a wheel balancing weight? But wouldnt I feel it when I drove all the time? Calipers are ok..just mught have to check a few things over again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR0582 »</TD></TR><TR><TD CLASS="quote">HEY I USED TO BE A TECH AT HONDA AND NOW I WRIGHT SERVICE FOR HONDA AND THE PULSATING CAN BE FROM BRAND NEW ROTORS. SOMETIMES YOU HAVE TO CUT BRAND NEW ROTORS, TRUST ME. </TD></TR></TABLE>
Please stop yelling....and isn't it "write"?
but true about the new rotors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jomama »</TD></TR><TR><TD CLASS="quote">what does it mean to have rotors "cut?" i've never heard of this...
cut = resurfaced. this is to ensure the face of the rotor is smooth and level for maximum efficiency.
</TD></TR></TABLE>cut = resurfaced. this is to ensure the face of the rotor is smooth and level for maximum efficiency.
But it still did it before the new rotors were put on.
alphalanos
14
Sep 8, 2008 04:07 AM
