need help asap on type-r wiring and one code
Old Jan 30, 2008 | 10:10 AM
wolfdawg's Avatar
Default need help asap on type-r wiring and one code
I am running a jdm-r and a usdm p73ecu. I did the ckf trick but there was one problem I wired the blue/red stripe c1 with the yellow wire c4 and the white/red stripe c11 with c14 which is white. But my car has a black wire for c14?????
Rywire - Online Store
And one more thing I am geting one code. A p1259 what is the problem for that any help would be nice. Thanks Wolfy
Old Jan 30, 2008 | 06:12 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: need help asap on type-r wiring and one code (wolfdawg)
P1259 VTEC system malfunction.
https://honda-tech.com/zerothread?id=1812135
check under the OBD2 section in this link
Old Jan 31, 2008 | 02:00 AM
wolfdawg's Avatar
I need to add a Vtec Pressure Switches or should I just do what this guy said??
guess I will toss it out there as well for the JDM owners that do not have Vtec Pressure Switches and want to run USDM ECU's. Splice the Vtec Solenoid wire (Green wire with a yellow stripe) and Vtec Pressure Switch wire (Blue wire with a black stripe) together and this will fix it.
Thanks Wolfy
Old Jan 31, 2008 | 02:13 AM
wolfdawg's Avatar
And if I need to add a Vtec Pressure Switches can I just use one off my spare d16z6 or do I need to get one off a gsr???? Thanks Wolfy
Old Jan 31, 2008 | 04:41 AM
Technical Hero
yeah just use the D16's
Old Jan 31, 2008 | 05:14 AM
wolfdawg's Avatar
Default Re: need help asap on type-r wiring and one code (HondaPartsHero)
Ok and the best place to put it would be and do I need to re-pin any thing or dos it plugs right in or should I just trick it?
Old Feb 1, 2008 | 07:28 AM
wolfdawg's Avatar
Jakester9500
12
Aug 8, 2007 05:25 AM
lonefuzzy79
Apr 18, 2003 06:52 AM
pelotudo
Jan 30, 2002 03:02 PM
pelotudo
Jan 30, 2002 11:43 AM
