Do i need to remove crank pulley if timing if a teeth off?
Old Jan 29, 2008 | 05:35 PM
Powered by VTEC's Avatar
Default Do i need to remove crank pulley if timing if a teeth off?
Do i need to remove crank pulley to adjust timing belt if timing if a teeth off? cause i know i have to take valve cover off and upper timing belt cover off. but if i dont have to take the crank pulley and lower timing belt off, that will save me some time.cause i am just adjusting the belt ,not to replace the old one.
please advise. thanks
Old Jan 29, 2008 | 05:38 PM
z6hatchboy's Avatar
Default Re: Do i need to remove crank pulley if timing if a teeth off? (Powered by VTEC)
It would be best to take the crank pulley off so you can use the refference marks on the oil pump to put it back in time for sure.
preludedriva's Avatar
no
unless you are removing and replacing the belt all together
remove the covers
TDC the crank pulley
then TDC the gear (s)
and have it
Old Jan 29, 2008 | 05:58 PM
rivaladore's Avatar
Default Re: Do i need to remove crank pulley if timing if a teeth off? (preludedriva)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludedriva &raquo;</TD></TR><TR><TD CLASS="quote">no
remove the covers
and have it</TD></TR></TABLE>
loosen the tensioner as well
1320london
Jul 29, 2017 02:55 AM
joiv21
11
May 16, 2013 06:50 AM
toniandfredo
Honda Civic (2001 - 2005)
Jun 10, 2007 06:28 PM
EG2Driver
Jun 15, 2006 07:24 PM
virusiidx
Jan 6, 2005 06:38 PM
