Help!! Possible Transmission Problem?? Civic EX 94
Old Jan 29, 2008 | 05:24 PM
xiongstah's Avatar
Default Help!! Possible Transmission Problem?? Civic EX 94
I was on the Hwy during rush hour, so was shifting constantly from 2nd to 3rd etc, when my torque suddenly changed. From then, my 1st and 2nd gear doesn't seem to accelerate as fast anymore. Since I have been driving that car for awhile, I know something was wrong when I'm forced to shift at only around 2000 rpm because it sounds as if I was at 3000 rpm. My 4th gear seems to be ok but my 5th gear has no power whatsoever. I checked all my fluids (oil, coolant) and they were ok. Someone please give me an insight on what they think I should do and what's wrong.
Old Jan 29, 2008 | 05:25 PM
z6hatchboy's Avatar
Default Re: Help!! Possible Transmission Problem?? Civic EX 94 (xiongstah)
Timing? Are there any CEL's?
Old Jan 29, 2008 | 05:28 PM
xiongstah's Avatar
Default Re: Help!! Possible Transmission Problem?? Civic EX 94 (z6hatchboy)
In not sure what CEL's are
Old Jan 29, 2008 | 05:46 PM
rivaladore's Avatar
a CEL is a Check Engine Light.......Its a yellow light on your cluster.....If you have one click on the link, it will help you diagnose the CEL if you have one. If not then check your timing. Use the search button to figure out how to do it, if you can't figure it out take it too a shop bc you might not understand how to do it. Autozone reads codes for ODB2 vehicles(96 or newer) for free
https://honda-tech.com/zerothread/1901557
Modified by rivaladore at 12:01 AM 1/30/2008
Old Jan 29, 2008 | 05:58 PM
xiongstah's Avatar
Default Re: Help!! Possible Transmission Problem?? Civic EX 94 (rivaladore)
Ok I'll check it out, thnx alot.
Mike Makovsky
Jan 24, 2013 05:25 PM
05blucvcse
Honda Civic (2001 - 2005)
Oct 26, 2008 10:08 AM
reloaded
May 16, 2008 03:18 PM
chinkest_raver
Sep 22, 2006 06:53 AM
vg7z
13
Apr 23, 2005 07:21 PM
