crx SI rod bearings???
Old Jan 29, 2008 | 02:18 PM
lancerkid06's Avatar
Default crx SI rod bearings???
im suppossed to be picking up this crx from a friend of mine in a couple weeks for $500 .... the only thing wrong with it is the number 2 rod bearing ... so i was wondering how hard it would be to replace the rod bearings ... i dont really have the money for a swap and i can get a set of rod bearings for like $60 at advance .... by the way its a d16a6 .. stock crx si motor .... or how hard it would be to change them myself ..
pics of the car
alarm, rims, lowered, tinted windows, glow gauges, racing steering wheel, short shifter, integra seats, amber corner lights, full exhaust, intake, new stock header.... dont know the brands but will figure out
Modified by lancerkid06 at 3:32 PM 1/29/2008
Old Jan 29, 2008 | 03:10 PM
t25d16a6's Avatar
Default Re: crx SI rod bearings??? (lancerkid06)
you can't just replace rod bearings if it's spun....you need a new crank/possibly machine old one
Old Jan 29, 2008 | 03:16 PM
well that sucks ... i dont really know what he did to make it happen .. but i talked to the guys dad yesterday and he said the only thing wrong was the #2 rod bearing messed up ... and i looked up replacement ones and its like $60 a set ....
what would i need to do to check the condition of them to make sure that is the problem.....
Old Jan 29, 2008 | 03:21 PM
t25d16a6's Avatar
Default Re: (lancerkid06)
you can pop the oil pan off and pull the rod caps to see the extent of the carnage...you will end up pulling the motor to fix it if it's a spun bearing, or pick up another cheap d series
Old Jan 29, 2008 | 03:35 PM
yeah how much do you think a rebuild for the motor would be ... or what motors would just drop in without having to buy anything extra besides like the engine its self
Old Jan 29, 2008 | 03:45 PM
t25d16a6's Avatar
a rebuild will cost a fortune to have someone do it. If the damage isn't too bad, then I would just wait for a cheap d16 crank to come up on ebay and throw that in there with new bearings, but it really isn't the best/easiest idea. If you want an easy drop in then just get a sohc zc non vtec from japan from somewhere like hmotorsonline.
Old Jan 29, 2008 | 04:50 PM
Tippyman's Avatar
Default Re: (t25d16a6)
SOHC ZC from HMO is $399 and is literally a direct drop in.
Old Jan 29, 2008 | 05:27 PM
yeah i saw that but there out of stock ...how much better is that motor than the stock d16 by the way ..
Old Jan 29, 2008 | 05:38 PM
t25d16a6's Avatar
it's not better than a stock d16a6...they are about the same
also can you guys tell me some more sites that would be good to get a motor from .... thanks
flatbebo
Jan 11, 2009 01:41 PM
EdoMoto
22
Sep 25, 2003 10:05 PM
Plan B
Oct 18, 2002 06:42 AM
Sonny
Aug 23, 2002 08:06 PM
