How much MPG am I supposed to be getting in my 00 V6?
Old Jan 28, 2008 | 10:15 PM
preludedriva's Avatar
Default How much MPG am I supposed to be getting in my 00 V6?
im getting like 20 maybe tad bit more on the freeway and i drive conservativly
or is that normal?
Old Jan 28, 2008 | 10:42 PM
YeuEmMaiMai's Avatar
Default Re: How much MPG am I supposed to be getting in my 00 V6? (preludedriva)
mixed I was getting 25 in my 98LX V6 coupe
highway was 34 mpg at 70mph
even in my current car I get at least 21 city and 31 highway...........something is wrong and you need to find out what it is
Old Jan 29, 2008 | 12:10 AM
i am not throwing any codes and i dont smell and excessive amount of fuel coming from anywhere
Old Jan 29, 2008 | 12:23 AM
trans slipping?
V6 should be approx 2200@70
Old Jan 29, 2008 | 12:31 AM
Default Re: How much MPG am I supposed to be getting in my 00 V6? (YeuEmMaiMai)
yeah that sounds bout right
my trannies fine shifts smooth and everything after warm up of course
Old Jan 29, 2008 | 12:40 AM
run some seafoam through the engine
run a can of seafoam into the gas tank to clean injectors
check for brake drag
check 02 sensors
check fuel pressure
Old Jan 29, 2008 | 12:43 AM
i always thought seafoam was bad for the car?
Old Jan 29, 2008 | 01:44 AM
only if you hydrolock the engine with it.
seafoam is nothing more than auto trans fluid additives (basically very kick *** detergents) and it will make short work of carbon deposits in the intake track of the car and will clean your injectors out within 1 tank of gas.
Old Jan 29, 2008 | 02:00 AM
i was actually reading up on it before rechecking this thread
ima fill my tank tommorrow with plus instead of unleaded and put a 1/3 of seafoam bottle in there or techron whichever i can get my hands on see what happens then
ive yet to even pop the hood on the car i should check the plugs and filter do some basic maintance dono if it was done yet all i know is the 100k belt and pumps were done
Old Jan 29, 2008 | 02:07 AM
OK do you know any honda techs? get them to diag the 02 sensors and cat ( use an infared temp reader)
low 20s on the highway isn't possible unless you are going like 110+ I still got above 30 at 85 when I had my car
Old Jan 29, 2008 | 09:28 AM
well i just took the air filter out and its the dirtiest k and n filter i have ever seen in my entire life lol
i just washed it and i am letting it dry right now
Old Jan 29, 2008 | 11:58 AM
aries331's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">run some seafoam through the engine
I would do some research before messing with seafoam. It only works if done correctly.
Old Jan 29, 2008 | 02:53 PM
Default Re: How much MPG am I supposed to be getting in my 00 V6? (aries331)
done it with my last 4 cars and no issues.......
suck a little though at a time via brake booster (1/3 can) turn car off let it sit 15-20 mins start back up and pour some in the gas tank
Old Jan 29, 2008 | 04:47 PM
im going to use techron or some other fuel injector cleaner
Old Jan 29, 2008 | 04:52 PM
VTEC_PRODUCTION's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludedriva &raquo;</TD></TR><TR><TD CLASS="quote">im going to use techron or some other fuel injector cleaner</TD></TR></TABLE>
your retarded. seafoam is the next best thing since sliced bread. buy something else and your wasting your money...i cant tell you how many engine additives i have used and only seafoam has given me the BEST and MOST NOTICEABLE results...
Old Jan 29, 2008 | 05:02 PM
Default Re: How much MPG am I supposed to be getting in my 00 V6? (VTEC_PRODUCTION)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_PRODUCTION &raquo;</TD></TR><TR><TD CLASS="quote">
your retarded. seafoam is the next best thing since sliced bread. buy something else and your wasting your money...i cant tell you how many engine additives i have used and only seafoam has given me the BEST and MOST NOTICEABLE results...</TD></TR></TABLE>
i am retarded? ok? proper english would have been 'you are retarded' perhaps you are the one who is retarded?
ive rather use something that people dont have to ask about using cause from what ive seen everyone has been asking how to use seafoam and it does the same thing as o lets say lucas fuel injector cleaner so why not?
o btw i filled the car up after cleaning the filter.....drove bout 70 miles and filled it back up and it took about 2.5 gallons to refil so i guess i am getting the good gas mileage again
Modified by preludedriva at 2:19 AM 1/30/2008
Old Feb 5, 2008 | 06:37 PM
ok i still get like 21 i just refilled
i went through 16 gallons going 360 miles
my plugs seem fine and i cleaned my air filter since is k&n and its not throwing any codes
Old Feb 6, 2008 | 05:22 PM
well apparently the fuel filter is in the fuel tank so that i dont have to change it lol
Old Feb 8, 2008 | 12:09 AM
shoulda done this earlier i looked up my mpg online and it says 20 city to 28 high way
im a few mpgs off on mine i guess its cause i got 100k on it so yeah
egsickz0
Feb 10, 2011 07:52 AM
miked123
12
Mar 20, 2009 09:02 PM
h22HatchEG
Jul 5, 2006 10:52 PM
CRX Si
Mar 11, 2003 03:50 PM
sptsi00
Feb 3, 2003 01:20 PM
