aftermarket steering wheel + blinkers?
Old Jan 28, 2008 | 07:59 PM
PhrequenC's Avatar
Default aftermarket steering wheel + blinkers?
after taking off my steering wheel for the aftermarket one.. my blinkers must be manually turned off after takign a corner, is this right?
Old Jan 28, 2008 | 08:07 PM
Powered by VTEC's Avatar
Default Re: aftermarket steering wheel + blinkers? (PhrequenC)
no this is not right. i have an aftermarket steering wheel. and in fact a quick release one and my blinkers still work as normal.
Old Jan 28, 2008 | 08:15 PM
PhrequenC's Avatar
Default Re: aftermarket steering wheel + blinkers? (Powered by VTEC)
did you have an airbag and remove that whole assembly with it?
Old Jan 29, 2008 | 12:07 AM
jdmsiR20's Avatar
gotta leave the round cable reel in when you swap things over
Old Jan 29, 2008 | 07:55 AM
PhrequenC's Avatar
Default Re: aftermarket steering wheel + blinkers? (jdmsiR20)
any pics of what your talkign about?
Old Jan 29, 2008 | 07:57 AM
OMGWTFBBQ!'s Avatar
Ive got an aftermarket and dont have any problems with anything.
Old Jan 29, 2008 | 09:03 AM
blk92_d16's Avatar
You must have removed the clock spring mechanism; it releases the switch automatically after you straighten out the wheel after a turn.
Old Jan 31, 2008 | 10:50 PM
PhrequenC's Avatar
anyone have pics of their setups? (with steering wheel remove?)
Old Jan 31, 2008 | 11:06 PM
Eran's Avatar
HT White Ops
It's not the clock spring mechanism that does the signal cancel. It's the white (or black) bowtie-shaped piece on the combination (blinker/wiper) switch. You need to line the tabs on the bowtie with the notches on the steering wheel hub.
Old Jan 31, 2008 | 11:54 PM
saywhat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsiR20 &raquo;</TD></TR><TR><TD CLASS="quote">gotta leave the round cable reel in when you swap things over</TD></TR></TABLE>
Not true, you just need to leave the white plastic turn signal cancel mechanism in the column.
Old Feb 1, 2008 | 09:17 AM
PhrequenC's Avatar
Default Re: aftermarket steering wheel + blinkers? (saywhat)
i dont know what youre al talkign about what is the white thing i dont have 1
Old Feb 1, 2008 | 09:24 AM
saywhat's Avatar
http://www.hondaautomotivepart...WITCH
This is for a 97 Civic EX, hope that helps.
Old Feb 1, 2008 | 09:51 AM
PhrequenC's Avatar
i didn't remove that peice.. the only thing i took out was the airbag thing
Old Feb 1, 2008 | 11:18 AM
saywhat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhrequenC &raquo;</TD></TR><TR><TD CLASS="quote">i didn't remove that peice.. the only thing i took out was the airbag thing</TD></TR></TABLE>
Well what year/model car is this?
Old Feb 1, 2008 | 11:29 AM
Eran's Avatar
HT White Ops
Then you have it. You need to align the tabs on it with the notches in the steering wheel hub.
LIKE I SAID BEFORE.
crazyhouse2011
21
Apr 25, 2013 05:58 PM
emraldgtr1
Aug 8, 2007 05:47 PM
ek9tl
Jan 31, 2007 09:00 PM
dustin_crxsi
Oct 30, 2006 05:29 PM
krnboynemesis
Jul 14, 2005 09:44 AM
