aftermarket steering wheel + blinkers?
after taking off my steering wheel for the aftermarket one.. my blinkers must be manually turned off after takign a corner, is this right?
Re: aftermarket steering wheel + blinkers? (PhrequenC)
no this is not right. i have an aftermarket steering wheel. and in fact a quick release one and my blinkers still work as normal.
HT White Ops
It's not the clock spring mechanism that does the signal cancel. It's the white (or black) bowtie-shaped piece on the combination (blinker/wiper) switch. You need to line the tabs on the bowtie with the notches on the steering wheel hub.
Re: aftermarket steering wheel + blinkers? (jdmsiR20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsiR20 »</TD></TR><TR><TD CLASS="quote">gotta leave the round cable reel in when you swap things over</TD></TR></TABLE>
Not true, you just need to leave the white plastic turn signal cancel mechanism in the column.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhrequenC »</TD></TR><TR><TD CLASS="quote">i didn't remove that peice.. the only thing i took out was the airbag thing</TD></TR></TABLE>
Well what year/model car is this?
HT White Ops
Then you have it. You need to align the tabs on it with the notches in the steering wheel hub.
LIKE I SAID BEFORE.
LIKE I SAID BEFORE.
crazyhouse2011
21
04-25-2013 05:58 PM
ek9tl
01-31-2007 09:00 PM
