My Motor Has a Stutter Problem
its starts between 2to3500rpm ive already changed the coil/igniter, i put a aem fpr on i thought it was a fuel problem but it still does it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Taylor23 »</TD></TR><TR><TD CLASS="quote">its starts between 2to3500rpm ive already changed the coil/igniter, i put a aem fpr on i thought it was a fuel problem but it still does it </TD></TR></TABLE>
Did you replace both the coil and the igniter/ICM with OEM parts from the stealership? Usually the stutter is caused by the ICM dying. I've had terrible luck with aftermarket ICMs lately...went through 3, and 2 aftermarket coils before I got mine fixed. Turned out it was a bad coil.
