V-TEC is over rated
Old Jan 27, 2008 | 03:29 AM
Kool_Aid's Avatar
Default V-TEC is over rated
hello everyone, im building a DC2 Ls for my little bro and was wondering if the B20 non vtec would be a better power plant over the 1.8? also for a few more hund. i could have the B16. The idea is to install a comblete turbo setup. for the price of a Type R, a turbo would put a bigger chip on your shoulder. this will be his everyday driver so i want stock internals so he can get it fixed anywhere. Peace.
Old Jan 27, 2008 | 04:17 AM
StorminMatt's Avatar
Default Re: V-TEC is over rated (Kool_Aid)
The B20 is most definitely an upgrade vs the B18A/B18B. I upgraded from a B18B to a B20 several years ago. And I was amazed at how big of a difference that small displacement and compression increase made. Just keep in mind that the B20 is not the best block for boost, though. If you want more displacement, you would be better off resleeving the B18 if you are going to boost.
Old Jan 27, 2008 | 03:16 PM
swappedcx's Avatar
if vtec is overrated then why are you considering a b16?
If there is nothing wrong with your b18a/b block, why would you want to waste the money on another motor that your going to leave stock and turbo? I say keep the b18.
Old Jan 27, 2008 | 06:01 PM
Default Re: V-TEC is over rated (swappedcx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swappedcx &raquo;</TD></TR><TR><TD CLASS="quote">If there is nothing wrong with your b18a/b block, why would you want to waste the money on another motor that your going to leave stock and turbo? I say keep the b18.</TD></TR></TABLE>
This is a good point. I personally find the B18 to be rather limp-wristed when it comes to torque. But that's in allmotor form. If you are boosting, why bother changing.
Old Jan 27, 2008 | 07:26 PM
Garage 808 Hatch's Avatar
put some ARP rod bolts in the LS and boost away
Old Jan 27, 2008 | 08:46 PM
quicksilver1689's Avatar
i ♥ snails
garage 808 hatch has the nice idea, 300whp with a nice flat linear torque curve is what i would do.
Old Jan 28, 2008 | 11:22 AM
Honda Bull's Avatar
Default Re: (quicksilver1689)
Do the 1.8L if you've got it.
Same crank and rods as the B20 with slightly thicker sleeves. That means... a few more lbs. of boost. That will make up for the lack in displacement if you are on e a budget.
And like Garage 808 said, do rod bolts while you have the chance. Rev that bottom end to 8000 rpm safely. Next upgrade could be VTEC head or springs retainers/cams for the LS head.
On a side note... VTEC isn't exactly overrated. Take a stock LS and turbo it. Take a stock GSR and turbo it. All things being equal, the GSR cams are bigger and the head flows better to make much nicer power.
4thgenx42
Sep 25, 2006 04:15 AM
Ek9_6
Mar 6, 2003 11:39 AM
Finest
Aug 11, 2002 01:43 PM
wu tang
Jan 26, 2002 05:50 PM
