ls/vtec starting problem...
Old Jan 27, 2008 | 12:09 AM
GSR_hatch936's Avatar
Default ls/vtec starting problem...
jus swapped it in there, it keeps reving on its own high rpms i kill it once it passes 5 k the throttle body makes a pop noise aswell i cant think of what would be the problem i have tried switching sensors but it gets no where??? any one any clue...
Thankz!
Heres A Video
Old Jan 27, 2008 | 06:27 AM
RIZOBIZERT's Avatar
Default Re: ls/vtec starting problem... (GSR_hatch936)
Is there something holding the throttle body open? It shouldn't rev that high without air. Make sure your throttle cable isn't bound up in some way holding the throttle body open. I know this sounds elementary, but I can't imagine what else might be causing the idle to jump to 5,000+. You could try to disconnect the IAC valve, perhaps it's giving you issues.
Old Jan 27, 2008 | 06:36 AM
pdotjones's Avatar
Default Re: ls/vtec starting problem... (RIZOBIZERT)
throttle cable might be too tight...
Old Jan 27, 2008 | 01:13 PM
well we disconnected it from what holds the and turned it on and it stayed at 1 k and jumps to three on its own that holder is letting the tb open just a lil bit and makes it rev high..... whats my best bet?
shabam
Dec 9, 2007 07:52 PM
si0385.
Feb 3, 2006 08:19 PM
bumthology
Jan 13, 2006 09:06 AM
Des9255
Oct 24, 2005 09:58 PM
HATCHFREEK
Jun 13, 2003 12:47 PM
