there is only one way to install dizzy,right?
Old Jan 26, 2008 | 07:22 PM
Powered by VTEC's Avatar
Default there is only one way to install dizzy,right?
cause the nipple of the dizzy can easily be turned by accident, and i need to make sure i dont accidently turn nipple of dizzy 180 degree and install it.
need this confirm. thanks.
Old Jan 26, 2008 | 07:30 PM
pdotjones's Avatar
Default Re: there is only one way to install dizzy,right? (Powered by VTEC)
yeah its only one way to install it.....
Old Jan 26, 2008 | 07:50 PM
bmiller17's Avatar
Default Re: there is only one way to install dizzy,right? (pdotjones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdotjones &raquo;</TD></TR><TR><TD CLASS="quote">yeah its only one way to install it.....</TD></TR></TABLE>
x2!!
Old Jan 26, 2008 | 07:51 PM
Default Re: there is only one way to install dizzy,right? (bmiller17)
thanks guys
Old Jan 26, 2008 | 07:56 PM
bmiller17's Avatar
anytime!
Old Jan 26, 2008 | 08:00 PM
Bob Dole!'s Avatar
You can install it both ways. I've done it. It slides on easy the right way and the wrong way you need force to get it on. So if it doesn't slide in easy you have it 180 degrees off.
Old Jan 26, 2008 | 08:14 PM
Default Re: there is only one way to install dizzy,right? (Bob Dole!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob Dole! &raquo;</TD></TR><TR><TD CLASS="quote">You can install it both ways. I've done it. It slides on easy the right way and the wrong way you need force to get it on. So if it doesn't slide in easy you have it 180 degrees off.</TD></TR></TABLE>
thanks again. and it did slide in easy. so i think i got it the right way.cause i was trying to force it to get in. but it wont. but the other way around, it was easy.
Old Jan 26, 2008 | 08:58 PM
speedooo's Avatar
the keyway is staggered so it will only go in one way
Old Jan 26, 2008 | 09:02 PM
Chiovnidca's Avatar
Default Re: there is only one way to install dizzy,right? (speedooo)
They can be forced in the wrong way, seen it too many times from people trying to do their own repairs.
&lt;edit &gt; he said nipple
Old Jan 26, 2008 | 09:03 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
the keyway is staggered, but not very much... it will go in and bolt up the wrong way with enough effort , trust me. Same friend did it twice on two different cars!
94_civicEx
Nov 13, 2007 12:19 PM
vietherbs
Honda S2000
May 28, 2006 03:13 PM
cmsrally
10
Sep 25, 2005 03:22 PM
Kyles ej1
18
Sep 20, 2004 03:57 PM
Touch
11
Jun 15, 2003 01:24 AM
