92 civic si not getting fuel
Old Jan 26, 2008 | 05:04 PM
corked1260's Avatar
Default 92 civic si not getting fuel
i bought a civic but its not getting any fuel.when I put eather on it it Will run for a few seconds... battery is good, has new gas, I can hear the pump prime when i first turn the key on.... i need some suggestion im going to be taking a good look at it tomm.
i also have been searching but can not find anything really good
Shawn
Old Jan 26, 2008 | 05:10 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: 92 civic si not getting fuel (corked1260)
are you getting fuel pressure? ..are your injectors noiding ?
Old Jan 26, 2008 | 05:11 PM
random name's Avatar
Check your fuel injectors
Old Jan 26, 2008 | 05:21 PM
corked1260's Avatar
Default Re: 92 civic si not getting fuel (random name)
sounds dumb but what is a procedure to check the injectors? also any other ideas all these will be checked tomm? thanks alot guys
Old Jan 26, 2008 | 05:24 PM
Throwdown's Avatar
the correct way would be to have them flow tested....but you can just go down the line of diaoing this fuel problem and you will be able to tell...do you have fuel pressure ..(the right fuel pressure) is it making it to the injectors, are the injectors noiding... make sure the fuel reg is good..
Modified by Throwdown at 9:36 PM 1/26/2008
Old Jan 26, 2008 | 05:30 PM
corked1260's Avatar
to tell you the truth i do not know if i have fuel pressure i have not had a chance to check..... what i the correct way to do this also? thanks
Old Jan 26, 2008 | 05:31 PM
Throwdown's Avatar
Default Re: (corked1260)
i just told you my friend....
Old Jan 26, 2008 | 05:34 PM
corked1260's Avatar
i feel like a wicked newb but what do u mean by "are the fuel injectors noiding" sorry for being bad in this area
Old Jan 26, 2008 | 05:36 PM
Throwdown's Avatar
are they pulsing
Old Jan 26, 2008 | 05:59 PM
corked1260's Avatar
Default Re: (Throwdown)
i thought so ...... i will check everything i can think of tommarrow and post back after... thanks alot for your help
Old Jan 28, 2008 | 01:37 PM
corked1260's Avatar
so i worked on the car today.... i found out the fuel is going into the fuel rail\but thats where it stops so i have fuel pressure...... so im assumung that the injectors are not spraying what can i do to fix this..... thnks
shawn
Old Jan 28, 2008 | 02:38 PM
corked1260's Avatar
need some help i want to drive this car some more ,..... there is alos a check engine light on but i dont now how to read it...... my ef ahs a light on the ecu but this one dosent....
Old Jan 28, 2008 | 03:04 PM
corked1260's Avatar
helpppp me
Go run a search of CEL codes for you model
Old Jan 28, 2008 | 03:13 PM
corked1260's Avatar
i found that thanks but im still wondering what might ahve made the injectors stop spraying
Rikaro
Jun 11, 2011 05:40 PM
85
Jan 31, 2010 02:46 PM
Evil Smile
Sep 29, 2008 03:22 PM
midwesta
10
Aug 3, 2005 03:06 AM
ATS*Mark
Aug 7, 2004 10:12 AM
