3rd gear set
Old Jan 26, 2008 | 03:49 PM
Destructive-'s Avatar
Default 3rd gear set
im trying to replace my third gear set on the mainshaft, but the synchro sleeve is stuck onto the hub, i take it that its pressed it, how would i go about taking the sleeve and hub out, so i can take out the 3rd gear?
also, is the main bearing on the mainshaft supposed to be pressed in? when i opened my tranny up, it wasnt pressed...
thanks
Old Jan 26, 2008 | 08:35 PM
Legion's Avatar
* B A N N E D *
Default Re: 3rd gear set (Destructive-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Destructive- &raquo;</TD></TR><TR><TD CLASS="quote">how would i go about taking the sleeve and hub out, so i can take out the 3rd gear?</TD></TR></TABLE>
There's an easy trick. Take a 2x4 and drill a large hole in in. Make the hole larger than 2nd gear but smaller than 3rd gear. Then you can drop the mainshaft into the hole and it will stop when 3rd gear hits. Once you properly support the 2x4, you can smack the top of the shaft with a mallet a few times and everything will come apart. Just make sure you catch the mainshaft so it doesn't fall to the floor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">also, is the main bearing on the mainshaft supposed to be pressed in?</TD></TR></TABLE>
Nope. It slides right off.
Old Jan 29, 2008 | 08:15 PM
Default Re: 3rd gear set (Legion)
nice thanks guys, im in the process of putting everything back together, ill post a nice vid of the LSD working or something.
thanks for the help!
Old Jan 29, 2008 | 08:55 PM
IN VTEC's Avatar
If I know I'm not going to use the synchro rings again, I just turn it upside-down, hold the gear, and tap the end of the mainshaft on my wooden ramps until it loosens up.
TomCat39
Transmission & Drivetrain
Oct 11, 2016 02:26 PM
CubbyChowder
Jun 1, 2010 04:44 PM
killerpenguin21
10
Jun 3, 2009 02:01 PM
94turboeg
Jun 13, 2007 02:43 AM
HondaRcB
Nov 24, 2006 11:41 AM
