B16A OBD1 SWAP PROBLEMS!!!
Old Jan 26, 2008 | 11:53 AM
JDM_CRX_PLEASE's Avatar
Default B16A OBD1 SWAP PROBLEMS!!!
ok so long story short.
bought a ej1 coupe and got myself a b16A. the stamp on the head says 9/1 which means 1991 correct?
well anyways we swaped it in the car and we got a code which was vtec. fixed that and all the other problems. but now the car wont start..
it struggles to turn on, sounds like it has no gas but it primes so thats not it. we switched the map sensors and still nogo. we pulled out the spark plugs and found it was flooded with gasoline and we tried to start the car and it just backfires a lot but still wont crank over fully.
what do you think is wrong? the guy that helped me put the motor in says it could be the ECU but i dont want to belive him because almost every other problem he stated wasnt true so it starting to sound like hes just guessing.
how would i get that unburnd fuel out of my sparkplug area? and what do YOU guys think is wrong??
using a p28 ecu. stock b16 headers, brand new sparkplugs.
Old Jan 26, 2008 | 08:08 PM
kidrsx03's Avatar
Default Re: B16A OBD1 SWAP PROBLEMS!!! (JDM_CRX_PLEASE)
well if its obd0 motor in a obd1 car.. some wires might not be right.. umm id look into that
also check starter connections, dizzy, inside dizzy.... any not used wires.
Old Jan 26, 2008 | 11:56 PM
civicstar's Avatar
sounds like its not getting any spark, or the dizzy is going out, (cap or rotor)
Old Jan 27, 2008 | 09:34 AM
its getting spark
aidenbloomfield
Aug 18, 2013 02:17 PM
JDM_CRX_PLEASE
17
Jan 30, 2008 06:36 AM
JDM_CRX_PLEASE
Jan 27, 2008 12:20 PM
JDM_CRX_PLEASE
Jan 26, 2008 12:48 PM
