can someone help me out with this?
Old Jan 26, 2008 | 11:32 AM
JDM_CRX_PLEASE's Avatar
Default can someone help me out with this?
iknow is houldnt be posting up in the ITR section but i figured you guys would be the most mature and helpful on this. so please dont flame me and help me get this startd?
ok so long story short.
bought a ej1 coupe and got myself a b16A. the stamp on the head says 9/1 which means 1991 correct?
well anyways we swaped it in the car and we got a code which was vtec. fixed that and all the other problems. but now the car wont start..
it struggles to turn on, sounds like it has no gas but it primes so thats not it. we switched the map sensors and still nogo. we pulled out the spark plugs and found it was flooded with gasoline and we tried to start the car and it just backfires a lot but still wont crank over fully.
what do you think is wrong? the guy that helped me put the motor in says it could be the ECU but i dont want to belive him because almost every other problem he stated wasnt true so it starting to sound like hes just guessing.
how would i get that unburnd fuel out of my sparkplug area? and what do YOU guys think is wrong??
Old Jan 26, 2008 | 12:30 PM
Doespike's Avatar
Default Re: can someone help me out with this? (JDM_CRX_PLEASE)
Well, since you were polite about it
Spark plug wires in correct order on distributor? Distributor itself in good condition? Try swapping out known-to-be-good dizzy and ECU.
Old Jan 26, 2008 | 12:47 PM
Default Re: can someone help me out with this? (Doespike)
thanks does spike.
well im getting ready to head out to my friends garage. he also thinks its the ECU. were gonna try to swap them out today and see if it is that problem.
thanks again
Old Jan 26, 2008 | 02:32 PM
sheekdude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doespike &raquo;</TD></TR><TR><TD CLASS="quote">Well, since you were polite about it
Spark plug wires in correct order on distributor? Distributor itself in good condition? Try swapping out known-to-be-good dizzy and ECU.</TD></TR></TABLE>
if not, check the timing.
Old Jan 26, 2008 | 02:36 PM
migs's Avatar
Default Re: can someone help me out with this? (sheekdude)
It sounds like the wires arent plugged up in the right order.
FWIW, I wish Wandy whooped up on Chuck.
Old Jan 27, 2008 | 12:20 PM
fourthgenhatchB17's Avatar
Default Re: can someone help me out with this? (migs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_CRX_PLEASE &raquo;</TD></TR><TR><TD CLASS="quote">
it struggles to turn on, sounds like it has no gas but it primes so thats not it...we tried to start the car and it just backfires a lot but still wont crank over fully.
Pull off the distributor cap and see if the rotor screw came loose and fell out.
JDM_CRX_PLEASE
17
Jan 30, 2008 06:36 AM
JDM_CRX_PLEASE
Jan 27, 2008 09:34 AM
JDM_CRX_PLEASE
Jan 26, 2008 12:48 PM
killrB
Sep 14, 2007 04:35 PM
DizDitto
16
Oct 9, 2003 10:21 PM
