Wierd Transmission?
Old Jan 26, 2008 | 10:34 AM
Louzerz's Avatar
Default Wierd Transmission?
I have a 97 civic Hx auto that **** the bed so I bought a 99 civic auto trans from the local junkyard and when I brought it hom it looks completly different. The dipsticks are on oposite sides and the new trans has two Vtec solinoid looking things on it.
Can anyone tell me what the problem is?
I was told the trans from 96-00 are the same.
Old Jan 26, 2008 | 11:34 AM
austinkli's Avatar
Default Re: Wierd Transmission? (Louzerz)
what did you get the new tranny from, an hx? an si?
Old Jan 26, 2008 | 11:56 AM
Louzerz's Avatar
Default Re: Wierd Transmission? (austinkli)
He didnt say. It was on the shelf with the words civic auto 99 in yellow ink from a civic they had afew months ago. My guess is that it is not is Si model because its an auto no a 5 speed.
Old Jan 26, 2008 | 12:00 PM
pdotjones's Avatar
there should be a serial code on the trans casing. within that code it will tell you what tranny it is and from what car....
Old Jan 26, 2008 | 04:18 PM
boostedjdmdc2's Avatar
Default Re: Wierd Transmission? (pdotjones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdotjones &raquo;</TD></TR><TR><TD CLASS="quote">there should be a serial code on the trans casing. within that code it will tell you what tranny it is and from what car....</TD></TR></TABLE>
Old Jan 26, 2008 | 04:24 PM
Syndacate's Avatar
Default Re: Wierd Transmission? (boostedjdmdc2)
It's probably the CVT transmission that came in some HX civics from '96-'00.
CVT = Continuously Variable Transmission.
It's a very good concept if it wasn't "geared" (no pun intended) towards economy.
Old Jan 26, 2008 | 05:33 PM
Louzerz's Avatar
Default Re: Wierd Transmission? (Syndacate)
I currently have an Hx (CVT) transmission.
I called the junkyard I bought it from and he said its a so-called BASE tranny.
My new question is can I install this BASE tranny?
If anyone has info on this topic please let me know.
Old Jan 27, 2008 | 05:04 AM
Louzerz's Avatar
TTT
Modified by Louzerz at 10:20 AM 1/27/2008
Old Jan 27, 2008 | 09:21 AM
Louzerz's Avatar
TTT
Old Jan 27, 2008 | 09:35 AM
Historyg's Avatar
the tranny you bought bolts onto the car, but it will not work, you have a cvt tranny in the hx and you bought a regular 5 speed tranny from most likely a ex or dx 1999, you will have to do a lot more then just change out the tranny, you will have to buy a ex or dx auto ecu whichever you have, the hx ecu is built to work with the cvt not with the regular tranny's from the other models, you should return that tranny to the junk yard if at all possible and look for a hx auto tranny.
Old Jan 27, 2008 | 02:30 PM
Louzerz's Avatar
Default Re: (Historyg)
It is not a maunal trans. Its a auto with the torque converter and everything.
Old Jan 27, 2008 | 02:50 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Louzerz &raquo;</TD></TR><TR><TD CLASS="quote">
I was told the trans from 96-00 are the same.</TD></TR></TABLE>
You need 96-98 trans, 99-00 are different with more sensors as you see
Jizzmaster Zero
Aug 4, 2005 07:08 PM
dubman410
Nov 29, 2004 09:12 AM
Lei Siew Long
Jun 21, 2003 09:45 AM
