I need Help!!! My Eg wont start!!!
I'm having a bit of a problem with my eg, it does not want to start!!
Symptom's :
car cranks but will not kick on completely. fuel pump does not engage upon opening ignition switch. engine light comes on but after a few seconds it turns off.
I have spark and the compression is good.
i changed the fuel pump today so i know it's not the pump it self.
does anyone have any suggestions on what it might be?
Please be serious on the topic, this is a real issue and i need someones help!
thanks Mike!!!
Symptom's :
thanks Mike!!!
fuses are all good. i put my hand on the main relay as i turn the ignition switch to on and it appears to click. is anything else not supposed to work if the main relay is out?
Symptom's :
thanks Mike!!!
Symptom's :
thanks Mike!!!
When you put your hand on your main relay...
it sould click once when u
turn the key to the run position.
Then click AGAIN once the CEL goes out.
That is your pump prime.
Your pump wasnt the problem.
Hope this helps u in the future.
RecklessEJ
15
Sep 18, 2011 03:56 PM
acidburn2k2
Dec 10, 2009 06:25 AM
rsanders21
Oct 30, 2007 10:22 PM
