I need Help!!! My Eg wont start!!!
I'm having a bit of a problem with my eg, it does not want to start!!
Symptom's :
car cranks but will not kick on completely. fuel pump does not engage upon opening ignition switch. engine light comes on but after a few seconds it turns off.
I have spark and the compression is good.
i changed the fuel pump today so i know it's not the pump it self.
does anyone have any suggestions on what it might be?
Please be serious on the topic, this is a real issue and i need someones help!
thanks Mike!!!
Symptom's :
thanks Mike!!!
Re: I need Help!!! My Eg wont start!!! (austinkli)
Symptom's :
thanks Mike!!!
Symptom's :
thanks Mike!!!
When you put your hand on your main relay...
it sould click once when u
turn the key to the run position.
Then click AGAIN once the CEL goes out.
That is your pump prime.
Your pump wasnt the problem.
Hope this helps u in the future.
^^ exactly, there's no need to put your hand on it, you could hear it click, if it doesn't your car more likely won't turn on.
acidburn2k2
12-10-2009 06:25 AM
rsanders21
10-30-2007 10:22 PM
