Thinking about getting a chipped ECU.. What should I look for?
Old Jan 25, 2008 | 10:07 AM
Razr2's Avatar
Default Thinking about getting a chipped ECU.. What should I look for?
I have a 2000 Civic Si with I/H/E, a BM FPR, and a CTR intake cam. I want to get a chipped ECU w/ conversion harness to OBD1.
My friend has an OBD1 harness he can give me, so all I need is the ECU.
Can I buy any ECU that is chipped for a b16, or is it better to get one chipped specificaly for my setup? That will run me about $175 but I can get a used one for alot cheaper. What are the differences?
Also can I do my motor any harm by running a chipped ECU? Is it possible to run to lean or to rich or to affect the motor in any way whatsoever?
How much HP gains can I see from a chipped ECU?
Thanks, all info appreciated.
Old Jan 25, 2008 | 10:36 AM
JKov240's Avatar
Default Re: Thinking about getting a chipped ECU.. What should I look for? (Razr2)
http://www.phearable.net
You can get the ECU and the chip that is tuned for your set-up for ~$175 if I remember correctly (been a while since I ordered mine).
To answer your questions...
1)It's better to get one that's tuned for your set-up.
2)No, unless the tune isn't right...most tuners tend to make it run a little rich, just to be on the safe side.
3)Phearable.net claims ~15hp (not sure if it was wheel or not, check the website), but I know that I most definitely felt a difference in between my old set-up and the new phearable.net one.
Old Jan 25, 2008 | 03:53 PM
JAYDmManny1331's Avatar
yeah they do pretty good !! phearable !!
Old Jan 25, 2008 | 05:17 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: (JAYDmManny1331)
i would try to find a chipped p30 because it has a knock board, and just have it street tuned... there are a couple of tuners in miami, and a bunch in south florida
Old Jan 25, 2008 | 07:47 PM
Razr2's Avatar
Default Re: (oneludesol)
Anyone else? bump
Old Jan 25, 2008 | 07:51 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: (Razr2)
thats kinda the only right answer sweetheart... If you are looking for permission to run around on a generic base map so you feel better about it, go ahead, but it wont be right. A modified engine will never be right until it is tuned on a wideband by someone who knows what the **** they are doing.
Old Jan 25, 2008 | 08:17 PM
b18c5 EG's Avatar
im wondering the same stuff....i have a b16 del sol ecu forget which one that is maybe p30?? should i send it in to get chipped by phearable.net with hondata s100 or should i just order one already chipped???im going to be running b18c5 block
Old Jan 26, 2008 | 06:56 PM
SQ is the SQUAD's Avatar
i chip alot of ecus myself. if your intrested pm me. but i only load stock basemaps on them. like said before, you sohuld always get your car street or dyno tuned. you can have 2 of the same cars, with the exact same set up, and get different results when tuning. i can adjust the basic stuff like vtec redline 02 settings ect, but as far as timming/fuel maps i tell all my customersa to get there ecu tuned.
Old Jan 26, 2008 | 10:45 PM
Razr2's Avatar
Default Re: (SQ is the SQUAD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SQ is the SQUAD &raquo;</TD></TR><TR><TD CLASS="quote">i chip alot of ecus myself. if your intrested pm me. but i only load stock basemaps on them. like said before, you sohuld always get your car street or dyno tuned. you can have 2 of the same cars, with the exact same set up, and get different results when tuning. i can adjust the basic stuff like vtec redline 02 settings ect, but as far as timming/fuel maps i tell all my customersa to get there ecu tuned.</TD></TR></TABLE>
Can I get my stock ECU tuned? Or do I need an obd2 ECU like a p28?
Can I just get a stock p28 w/ conv harness and have it tuned right then and there or does it have to be chipped, then tuned?
How much does a street tune usually cost and how much power can I see from it?
Old Jan 27, 2008 | 05:12 AM
Default Re: (Razr2)
you cannot get a tune on a stock ecu. thats the whole puprpose of the chip, so that they can edit the program. also when buying a chipped ecu, its dosent have to be a p28, just make sure its a vtec ecu if you have vtec. i can take a dx automatic ecu, chip it and make it an exact replica of a p28.
Old Jan 27, 2008 | 06:29 AM
1988_96hb's Avatar
Default Re: (Razr2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Razr2 &raquo;</TD></TR><TR><TD CLASS="quote"> Or do I need an obd2 ECU like a p28?</TD></TR></TABLE>
p28's are OBD1
Old Jan 27, 2008 | 08:55 AM
Razr2's Avatar
Default Re: (1988_96hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988_96hb &raquo;</TD></TR><TR><TD CLASS="quote">
p28's are OBD1</TD></TR></TABLE>
Sorry, that's what I meant. Typo.
And I meant can I get my STOCK obd2 ecu chipped/tuned, or only an obd1 ecu?
Old Jan 27, 2008 | 09:24 AM
doood's Avatar
been there done that
Default Re: (Razr2)
only obd1 ecu's can be chipped
Old Jan 28, 2008 | 01:54 AM
if you have an obd2 car you will need to get the correct obd conversion harness and then you can rin the obd1 chipped ecu
DaddyKin
14
Jul 12, 2011 01:52 PM
1998GsRIntegra
Aug 10, 2010 11:34 AM
BrandonB16
Feb 17, 2009 05:33 AM
em1_fox
48
Nov 5, 2008 06:18 PM
option2type6
Northeast (Sales)
Nov 18, 2007 03:02 PM
