oil in the intake manifold
ok set up is a ls/vtec 93 ls blk 96 b16 head new rings /valvestem seals oil pump
water pump headgasket all new now i thought it might be the head studs but a
friend told me oil in the IM is a pcv problem we never changed it when building the
motor anyway could that be it cuz its burning alot of oil i took of the headers and
theres oil coming from 1 & 3 cly could it be the pcv please let me now also do i really need that damn pcv box or can i take it off
i would be pissed if thats the prob sumthing so dumb like that but imma get 1 to see if thats the prob cuz my car been sittin in my garage for a long tim cuz of this we havent been able to figue out the prob but imma try that do i get the whole box or just ask for a pcv valve
Your PCV valve is designed to suck oil vapors from the block into the intake manifold. Eliminate it all together and run a catch can in line to keep things clean and properly vent pressure from your crank case.
i replace the pcv but its still smokoing here r sum pics
heres the new pcv
heres inside my intake
[IMG]http://i83.pho[IMG]
now hers the exaust ports
number1
number 2
nu
mber3
number4
heres the new pcv
number1
number 2
nu
mber3number4
i did but its still smoking i clened all 4 of the ports then ran it with the new pcv then took of the headers n these r the pics after i ran it still burning oil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic9390 »</TD></TR><TR><TD CLASS="quote">You say it's still smoking?? Out of the intake manifold??? If it is check your Timing it must be off...</TD></TR></TABLE>
dont listen to this guy he has no clue what hes talking about. there is something wrong with your pcv system. its not just the valve, theres more to it than that. its smoking because its burning oil from the intake manifold.
oil out of your exhaust ports can be alot of things, blowby the rings, valve seals etc. you need to figure out where the oil is coming from. do a compression test, and leakdown test to see.
Landon
Landon
disconnect all the lines that are for the pcv and run the car, i had the same problem with mine so i ran a catch can, same thing, Rebuilt motor smoked like MAD, but now not a drop
Youcould try replacing the PCV valve. But otherwise, excessive amounts ofoil in the PCV system is a sign of excessive blowby forcing oil mist in the crankcase throught the PCV system, and into the intake manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 »</TD></TR><TR><TD CLASS="quote">
dont listen to this guy he has no clue what hes talking about.</TD></TR></TABLE>
Touche sir. lol
Touche sir. lol
well its not the headgasket either, but dont listen to any of us and go spend time and money on something you dont need to do if you want.
i love when people ask for help, you tell them what to do and then they continue to do what they think is right.
good luck chief!!!
Landon
good luck chief!!!
Landon
i just pulled off my tb cause im sending it out to get bored (motors not in car btw) and i noticed the same problem i have alot of oil in the tb and a shat load more in the intake manifold. hmmm makes me wonder if i need to replace the pvc valve wtf y not they cheap but what about a catch can how does that work exactly and it elimanates the pvc? sorry if these are stupid questions
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tazzsi84 »</TD></TR><TR><TD CLASS="quote">so i should eliminate the pcv system? and yes the num 1 and num 3 spark plugs have oil num 3 the most</TD></TR></TABLE>
i would do a compression test and see if you getting lower numbers in #1 and #3. if you are then its probably rings. if not then you need to evaluate your pcv system. eliminating it and installing a catch can is an easy way to be sure it will function properly.
but if it is noticably differnt in 2 of the 4 cylinders, then its probably NOT your pcv system
Landon
Landon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tazzsi84 »</TD></TR><TR><TD CLASS="quote">did a compresion test good numbers all across im trying to get a leakdown test see wuts up cuz its geting me mad</TD></TR></TABLE>
Do a leakdown and report back.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zaraki »</TD></TR><TR><TD CLASS="quote">
Do a leakdown and report back. </TD></TR></TABLE>
agree. you should do a cylinder leakage test. im highly leaning towards your piston rings. did you install it correctly?
qais_vtec
Oct 8, 2018 12:21 AM
SIR_APPROVED
Feb 22, 2010 10:21 PM
andrew dc
May 4, 2003 07:06 AM
