testing engine out of car
Old Jan 24, 2008 | 06:57 PM
turbo sol's Avatar
Default testing engine out of car
is there a way to run a compression check or something on an engine that has been removed from a car?
I am looking at buying an engine, but its already been pulled. just wondering if there is anythign I can check besides a hole in the block.
Old Jan 24, 2008 | 07:28 PM
4XmattX2_0X's Avatar
Default Re: testing engine out of car (turbo sol)
u could crank the motor manually from the crank pulley bolt
Old Jan 25, 2008 | 01:06 AM
Legion's Avatar
* B A N N E D *
Default Re: testing engine out of car (4XmattX2_0X)
Leakdown test. Also check the spark plugs for signs of detonation.
Old Jan 25, 2008 | 10:15 AM
turbo sol's Avatar
Default Re: testing engine out of car (Legion)
i don't think I could spin the crank by hand fast enough to get an accurate compression test.
can i use the compression tester for the leakdown?
Old Jan 25, 2008 | 02:23 PM
Legion's Avatar
* B A N N E D *
No, you need a leakdown tester.
Old Jan 25, 2008 | 03:29 PM
4g hatch's Avatar
if the tranny is on and the starter is there then hotwire the starter and crank it over. pull all the plugs and hold the throttle open. it wont read as high cold but it will let you know if theres any variation
Old Jan 25, 2008 | 06:14 PM
boostedh22lude1's Avatar
Default Re: testing engine out of car (4g hatch)
if they didnt drain the oil check that, pull the valve cover check the t belt, and the cams for wear and how clean the head is.
pinecone
Jul 19, 2006 06:29 PM
michael_antoi
Sep 30, 2005 05:26 PM
logictron2000
Jun 16, 2003 07:17 PM
Propulsion
Feb 14, 2003 11:11 AM
JCracer723
Aug 21, 2002 07:50 PM
