Wheel bearing replacement
Old Jan 24, 2008 | 06:53 PM
si vtec ftw's Avatar
Default Wheel bearing replacement
scale of 1 to 10
how much of a bitch on an EF Si?
and...
how important is that metal plate behind my front brake rotors?
Old Jan 25, 2008 | 12:34 AM
Legion's Avatar
* B A N N E D *
Default Re: Wheel bearing replacement (si vtec ftw)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si vtec ftw &raquo;</TD></TR><TR><TD CLASS="quote">scale of 1 to 10
how much of a bitch on an EF Si?</TD></TR></TABLE>
10. Have fun.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">and...
how important is that metal plate behind my front brake rotors?</TD></TR></TABLE>
Not very. I threw mine away.
Old Jan 25, 2008 | 12:38 AM
Legion's Avatar
* B A N N E D *
Default Re: Wheel bearing replacement (Legion)
The bearing race sticks to the hub. You need to spend 10 hours grinding/sawing to get it off, or you can buy a press and spend 2 hours rigging **** to push it off. Either way it sucks. Trust. Oh, and you need to buy/rent a slide hammer to get the hub off. You also need a press to get the new bearing in without damaging it.
Old Jan 25, 2008 | 04:01 AM
NOOOOOOOOOOOO
you guys suck.
lol
but thanks
Old Jan 25, 2008 | 05:54 AM
97grnrs's Avatar
it can all be done on a press and with an air hammer to get that hub ring off. just dont put it in a way that u will warp the part where the studs are attached..
Old Jan 25, 2008 | 06:32 PM
boostedh22lude1's Avatar
Default Re: Wheel bearing replacement (97grnrs)
if u have acces to a press use a bearing splitter to get the race off the hub, if not u can cut it off with a cut off wheel, and to press the bearing back in u should really uae a press but it can be done without one get something to hold the hub up flat and set the bearing in, get a piece of flat steal and a 2x4 and a small sledge hammer and beat it on evenly it a pain but can be done, the brake dust sheild can be laft off but it looks ghetto
Old Mar 18, 2008 | 01:26 PM
Muckman's Avatar
Moderator in Chief
Default Re: Wheel bearing replacement (boostedh22lude1)
I had to cut the inner race to get it off. However I cannot find a replacement part number for it. Am I fuct?
*Edit: I was sent the wrong bearing without an inner race.
Modified by Muckman at 10:30 PM 3/21/2008
Old Mar 18, 2008 | 01:49 PM
non-VTEC's Avatar
Default Re: Wheel bearing replacement (Muckman)
i dont know what a new hub is worth but it might be cheap enough to just blast out the old bearing and install and new bearing with new hub. when i change them at work i dont bother with the old hub only because pulling the race off is a PITA. i charge the customer for a new hub at the same time.
so much easier/faster.
EX-T
15
Sep 12, 2008 06:53 AM
JCracer723
Suspension & Brakes
Nov 21, 2006 08:36 PM
EJ8VTEC
Feb 3, 2006 12:51 PM
monsterb18b
Sep 22, 2004 05:45 PM
crx_kid
Sep 7, 2003 03:29 AM
