Suspension & Brakes Theory, alignment, spring rates....
big job ahead of me
Old Jan 24, 2008 | 11:02 AM
sohctodohc's Avatar
Default big job ahead of me
ok so i have a full es bushing kit, cusco comp-s coil overs, manual steering rack to install, rear disc brake conversion, and two front lower ball joints, bleeding the brakes, and installing new rear pads.
im wanting to see from you guys how long yall think it will take do all of this?
i will have a press available but its about 2 miles from where i will be actually working on the car.(using bros car for transportation there and back).
any kind of guestimation would be appreciated.
Old Jan 25, 2008 | 09:02 AM
dynimitejack's Avatar
Default Re: big job ahead of me (sohctodohc)
Bleeding the breaks and changing the pads will be the easiest. with a full set of coil overs are you still goint to use factory struts? I just did upper control arms lower balljoints cv axles and shocks. that took me about 10 hours and I didn't have a ball joint press all I had was my good ol' BFH and a c-clamp.
Id give my self atleast 2-3 days in anticipation of any problems (i.e. parts breaking and having to special order from Honda)
Good Luck!
Modified by dynimitejack at 10:26 AM 1/25/2008
Old Jan 25, 2008 | 11:48 AM
sohctodohc's Avatar
Default Re: big job ahead of me (dynimitejack)
no full-coilovers come with there own shocks.
Old Jan 25, 2008 | 12:57 PM
sgallagher's Avatar
Everybody works differently. If you've done suspension work before then you should be able to do this in a weekend no problem. However you never know what will happen, you could run into a few snags along the way.
Its not hard work. You shouldn't have too much trouble. Plus theres plenty of info on H-T to help you along the way.
808k20a2
Oct 13, 2015 09:23 AM
kenzo42
Sep 2, 2013 10:17 PM
sakuraofthesea
Acura TL, RL & ZDX
Aug 4, 2012 08:04 AM
lude98SH
Aug 20, 2006 03:23 PM
DailyBlown
Jul 8, 2004 10:42 AM
